997.1 Tiptronic random key stuck issues
Dear rennlisteners,
Sometimes for some reason i cant remove the key from the ignition switch however the main problem is that the cluster shows “Lever in not P position” even though the car is in Parking and can be seen in the dash.
if i wiggle the key in the ignition key it will eventually be unlocked.
Has anyone seen this?
could it be an ignition switch issue or tiptronic related?
car is a 2005 997.1 S
User @ocmacman has this same problem. I believe he has traced it to a mechanical switch in the center tunnel with the Tiptronic shift lever and it does T know its in park when it is.
I don't own any 997 Tips so can't help you beyond that info and referral.
Good luck.
Good luck.
thank you very much Petza, i will look for him to share information
