What Spacers are you running?
Old 02-21-2019, 09:28 PM
Ohio Performance
Basic Sponsor
Ohio Performance's Avatar
Serious go with Adaptec! USA made, forum sponsor, and they give a nice discount!
High Temp Caliper Rebuild Kits; Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Old 02-22-2019, 12:45 PM
ElectricChair
ElectricChair's Avatar
997.2C2 - eibach pro-kit - adaptec 10mm front and 15mm rear
Old 02-22-2019, 01:10 PM
BradtheAg
BradtheAg's Avatar
Originally Posted by jamesinger
RSS 15mm spacers all around on EIBACH Pro Kit makes the car look how it should have from the factory IMO. I also have 305s in the rear FYI. I mainly felt 7mm in front wasn't enough when the car is lowered. 15mm seems solid when lowered.
Man that looks good. Maybe I'll hold off on swapping out the 15mm up front until after I lower. It definitely looks diffferent.
Old 02-22-2019, 09:25 PM
jamesinger
jamesinger's Avatar
Here is a pic from behind the day I got it done.
Can was suuuper dirty from all the debris in the canyons.
I think it is not too aggressively out there but not so sunken...perfect until I can get wheels and try to cram more rubber under there.
Eibach Pro kit = not too aggressively low.
H&R kit = 15mm is even less of a big deal because the drop cambers in the wheels to the point where I am assuming adjustable drop links would be smart.
Remember I am running 305s in back, so if you have 295s, 15mm is definitely chill. With the tires up front, it is NBD IMO.
Thank you for the compliment though. I thought about what to do and how to do it for a looong time before deciding because I know it will be a bit until I can get proper wheels.
Quick Reply: What Spacers are you running?
