997.1 wiring schemes
7th Gear
Hi All,
I was looking through the old threads and am hoping someone has the wiring diagram for either '05/'06 or '06/'07 - 997? Specifically schemes 19A. I would greatly appreciate your assistance.
Thank you.
Thank you.
7th Gear
The engine/DME connectors B & C to compare the connector pin locations #19 & #12.
After swapping an engine from a 2006 C2 into a 2007 C2 were getting a "Battery/Generator" light. The 997 is running great, no other errors - both the battery and alternator have been tested and are working perfect.
