I got the BOVEE 1000 with the cable that plugs into the usb and aux plugs in my center console.. however my Bluetooth won’t connect to the bovee. Do I have to disconnect my phone from PCM?
Not on my 2010. I can do calls, etc., and run the bovee through the iPod interface. There is an initial pairing sequence with bovee where you need to enter a code, 0000 I believe. Is the blue led on the bovee lighting up when you plug it in indicating it’s powered up?
