VF ENGINEERS KNOWLEDGE
VF-Engineering chose to supercharge the Audi S4 4.2 liter to provide a blistering launch from a standstill with a water cooled roots type Eaton TVS1900 supercharger. VF Engineers knew that only a roots type supercharger would give a torque increase needed to satisfy the hungriest enthusiast. The 1900cc supercharger unit was chosen for its superior efficiency when combined to the 4.2 V8 motor and provide plenty of potential for further upgrade-ability.
Maintaining the the original Audi quality, smoothness and reliability were the key factors in the VF design. VF have harnessed reliability of Eaton superchargers with their 15 years of supercharging experience and state of the art production techniques to create the ultimate water cooled supercharger system for the Audi S4.
All key components are 100% made in California. This system has been fully road tested and dyno tuned on the Mustang MD500AWD. The Audi S4 supercharger kit is setup at 5.5 psi and creates as much, if not more power than similar products running greater levels of boost. Installation is very simple and is fully reversible.
VF engineers spent several years developing, testing and refining the Audi S4 supercharger kit for consistency. Software flash technology and the latest Audi file versions have all been combined to provide the cleanest and most reliable method of end user software installation using the “Hex-Flash” programming cable. All test cars were put through long term full throttle testing in conditions varying from wet cold climates to hot dry Arizona desert temperature for safe-optimal air fuel ratios and knock activity monitoring. Competently-written ECU software has allowed VF to fully explore the potential of the Audi S4 engine.check for
The Eaton TVS1900 supercharger is mounted with a CNC machined aluminum cast intake manifold with an integrated water cooling heat exchanger. VF’s approach to supercharger development is quite unique when it comes to design and production style. The unit is accurately positioned in line with the original serpentine belt which is replaced with a longer OEM belt.
All supercharger systems are designed at VF-Engineering using state of the art technology. An example of this engineering is the employment of a Faro CMM to position and align the supercharger unit and offset for precise belt alignment. Exact belt alignment determine long term reliability of the drive belt, bearings and accessories. The supercharger unit is dowel pinned to the manifold and the manifold is dowel pinned to the cylinder heads to ensure optimal alignment consistency.
The key to this design is the OEM active-spring belt tensioner introduced by VF which minimizes belt slip and gives continuous drive for the supercharger. The supercharger intake is created for maximum air flow and draws through the throttle body, making the supercharger “pump” integral to the engines function. The integrated boost overrun system is designed for smooth off-throttle cruising and deceleration. know more The crankcase ventilation system is designed to cope with positive pressure. Higher capacity OEM fuel injectors are supplied fully assembled with new high capacity fuel rails and cross over fuel line which connects to the OEM fuel feed. The VF supercharger system remains fully OBD2 compliant and is supported by a 1 year unlimited mileage warranty on the product only.
Eaton TVS1900 roots supercharger
6061 Aluminum intake manifold
Internal bypass system
High flow cast supercharger inlet
Air water charge cooler system
Polypropylene water reservoir (US model)
High density water radiator
High flow water pump
Hard anodized 6061-T6 aluminum brackets
OEM serpentine belt and tensioner FEAD
Bosch high capacity fuel injectors
Hex Flash ECU tuning programming cable
Fully reversible
Made in California, USA.
Isn't everyone looking to do an Audi engine swap into their 997?
Its funny the title of the thread is VF Engineer's Knowledge. Makes you question that when they can't get their marketing posts into the right forum, unless the OP doesn't actually work for VF.
Does this mean I get free Netflix with the Audi supercharger? Now that's a deal.
Competently-written ECU software has allowed VF to fully explore the potential of the Audi S4 engine.check for 2019 fee netflix cookies
We're as baffled by this thread as all of you!
This account is definitely not directly affiliated with our company
in any way at all.
What is it about the non-RS GT3 allows an extra 2 psi of boost? The extra 200 rpms? Are these numbers with the factory headers/cats? I saw that your .1 GT3 was full bolt ons previously, so that would be nice to know. crime scene cleanup Michigan
Fully reversible
