Help in Xpipe install on 997.2
I am trying to remove central muffler to install xpipe however, I am not able to remove the rusted bolts. I already snapped 2 bolts as well as not able to take the stud out.
I have searched here to look what previous members did to remove but nothing worked for me. I soaked them with WD-40 many times over night. Then heated it with torch. I broke 2 bolts and still not able to take the studs. I don't want to attempt on 3rd bolt to leave exhaust hanging so I am seeking any suggestions on safe method without braking bolt. Also any suggestion on how to remove the stud, I tried to hammer the hell out of it and still not able to move it at all.
Anybody went though this and what did they end up doing? I also opened a thread in regional section looking for shop who can do it since I am not able to do it myself.
Are you talking about the three bolts on the cat flange? If so, a punch and good heavy hammer should pop a broken stud out pronto. I broke one of them doing my Fister install, and had no trouble getting the stud out of the flange.
Good idea to spray all the bolts/nuts liberally with liquid wrench and allow the penetrating oil to soak in for an hour or so. This should facilitate removal of the other fasteners. Additionally you will need a S shape wrench to get to the upper bolts more easily.
Peace
Bruce in Philly
It seems (from observing various posts/threads) that when people encounter this problem, a quick application of hammer and/or punch seems to pop them out for most of them. Coincidentally this includes a colleague of mine in literally the past few days.
But then there's a subset of folks that no matter how much thuggery they apply, they ain't moving. And they need to resort to drilling.
Sorry, don't know. But Car Fanatic / dc2000 is a Rennlist member, maybe send a PM to him ? He seems like a stand-up guy...
Karl.
Karl.
VT Blue (07-12-2020)
Karl.
Karl.
When you say a hammer with a punch. What does that mean? Do you have picture of a punch?
I PMed dc2000. Hopefully he gets back to me.
I can't believe Porsche would do horrible job on choosing better bolts than these. All other cars I had no matter how rusted the bolt is, I was able to take them out. These bolts being a stud is making job more difficult than what it should be.
A punch is simply a piece of steel used to drive the broken bolt out. Place the punch on the bolt and strike with a hammer.
https://www.harborfreight.com/hand-t...set-93424.html
Hi Kark,
OP is talking about these studs on the cat flanges. They are pressed-in on the flanges and are M8 x 1.25 thread. They corrode big time from combination of heat cycling, water and road chemicals. If they snap (and they will) you should be able to get the piece out of the flange with a decent punch and hammer. If you have problems with the top one (12 o'clock) removing the muffler or even the rear bumper will give you more access.
Cat exhaust studs. I used a 13mm ratcheting S wrench to get the top one off. Stud at 4 o'clock position is the one that broke on me.
I am happy that you are doing this work yourself, yet dismayed that you don’t know what a punch is (or how to look it up).
Use something like these and a heavy hammer and they should knock the studs out. They are studs, not bolts. They are pressed into the flanges of the catalytic converter and are held in place by a friction fit. If the punches do not work, they must be drilled out. And if the first two snapped, just assume that the other four will, too. Good luck!
