Lowering springs for 997.2 C2 Sports Chassis
Hi,
I'm looking for lowering springs which can be applied to 997.2 C2 with PASM Sports chassis.
Does anyone know if there is any product available?
Best regards,
NS
Best regards,
NS
So aftermarket PASM/SPASM springs from all the usual suspects (H&R, TechArt, Eibach, etc.) should fit your SPASM car.
There’s loads of threads discussing (and arguing
Karl.
Just remember you will be into diminishing returns here as you are already lower than stock and PASM.
SPASM is 10mm lower than PASM and 20mm lower than stock - so if your springs promise a 35mm drop over stock you'll only see 15mm drop from SPASM
Good luck with the mods!
I installed Eibach on my .1 C2 and love them. Its the perfect stance for a 997 and at $350 its a steal. They are slightly lower than a C2S but not slammed like H&Rs. I rarely scrape and its improved cornering stability as well.
I would also get 12-15mm spacers all around.
Ps - if you want to install them yourself I have a DIY writeup on it. Just check my profile and you will find it.
