winter storage = battery tender?
If you are asking about battery tenders I highly recommend the "Deltran Battery Tender". I have used the one that I have for over ten years. I use it to keep expensive lithium motorcycle batteries charged with no harm to the batteries. I use it on my 997.2 full time except for topping off other batteries. It is a small, plug into 115V wall outlet, step down transformer. It shows a red light when charging and a green light comes on when the battery is fully charged. Cheers
Received 5,413 Likes
Porsche's or Ctek.
Buy a Battery Tender. Get 4 for the price of the Porsche model, or a 3-4 bank Battery Tender unit to charge several in proximity without all the plugs. A 3-4 bank unit will probably run what the Porsche one does.
Originally Posted by roman944
where can I see the Porsche one? thanks guys
https://www.amazon.com/dp/B000FQBWCY/?tag=googhydr-20&hvadid=175781957198&hvpos=1t1&hvnetw=g&hvrand=2916381977051286389&hvpone=&hvptwo=&hvqmt=b&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028268&hvtargid=kwd-917009225&ref=pd_sl_3v7ijphsuu_b
https://www.suncoastparts.com/product/CHARGER2.html
Sir Thomas Lord of All Mets Fans
is there a specific model of CTEK and where can I see the Porsche one? thanks guys
This. Don’t need to buy an expensive Porsche brand that does nothing more than the trusty Battery Tender.
so like one of those CTEK 7002's just plug it in and leave for winter? should I bother starting my car every now and then and let it warm up to temp or no? and should I disconnect the tender/charger when doing so
some quick and easy Q's for you guys that have done this for years now I guess, I don't want to ruin anything
thanks again
thanks again
thanks again
thanks again
