I was driving my 05 C2S 51,000 miles to work this am and the Battery/generator warning light came on three different times in a 45 minute drive. The light only came on for a brief second then went away each time. The ! never came on. The car drove fine. The weather was 28 degrees and I was in slow moving traffic the entire trip. I’ve been driving this car the past week as I am having trouble w/ my 1series. No issues any this week w/ my 911 except for this message. Within the past three years I have replaced the battery, alternator and that battery strap thing.
I do do have a V1 that I believe is hard wired straight to the fuse box and a DSC w/ accelerometer. I did not have my cell phone charger plugged in. I only had the headlights on, ac set at 72 degrees and radio/Navi on.
No such thing as a fluke. Early earning of an issue but could be be battery, alternator, voltage regulator, who knows?
I’d stop at my Indy or P dealer or Auto Zone and see if they can plug in and find a fault code.
Also your Valentine may have a VDC display option so you could monitor the bus voltage static and charging. My Escort has this feature I leave it on as the default in the 993 and 997. Static should be about 12.5 vdc and charging 13.75 to 14.25 vdc.
I just ran to Firestone that is close to my work. They hooked up and checked my battery and alternator w/ their computer. They felt like it was fine. The mechanic just took a wild guess that it could possibly be a lose belt from the tensioner. Would this cause my light to come on & back off?
It probably threw a code.... If you have acess to a Durametric, you can read the deeper Porsche codes with a good description. Sometimes the descriptions can be really revealing.
If there is a code thrown, the Durametric will display it. You will want to check it as fast as possible, because some of the codes will reset if a condition is not repeated within a period of some sort.
The tapes look good for voltages. I suppose the belt could cause an intermittent issue more like instantaneous. Has the belt service been done? Was it wet when the lights came on? Thinking maybe a slipping belt like the old days when you drove through a puddle. Seems odd w a grooved serpentine belt though.
I would lean more on the side of a battery as it was cold. Two things kill batteries, hot and cold. You need to do a load test on the battery and not just a voltage test to see if it is good. Any car parts place will do that for free. I bet that is your issue.
I believe the test tape shows battery voltage drop while cranking - hence this is the load test of the battery. I’m not sure what the test parameters are but I think the tape is saying that the battery voltage didn’t collapse under cranking load. Hence a battery in good shape.
So crazy my car has driven just fine the past two days too & from work. About a 45 minute drive each time. I have romped on it and driven normal. I can’t believe that I’m having 1series trouble at the same time. I hooked up my Foxwell NT520 & cleared any codes Incase the car started acting weird so I could look it up. After I cleared the codes I realized that I should of looked at what I erased. Rookie move for sure.
Mechanic though it was a battery issue so he replaced it. Car drove fine for two days then the warning flashed again. Mechanic replaced the voltage regulator and I have made it two days trouble free. Hopefully this has satisfied the warning light situation. Here is a pic of the voltage regulator removed. The mechanic said that the two black tips should be the same size. One is just a little higher than the other. You can push them in & one side was just not making proper contact.
