997 turbo runs fine on tick over but not when revved
Hi guys I have a 997 turbo s and the other day it decided to start playing up
so what’s happening is it will sit ticking over all day and run completely fine however if you blip the throttle bring the revs up when the Rev drops down it then hunts and then cuts out? Turn ignition off and back on will idle fine until you blip the throttle again? Any help will be great? I’ve looked where I can for obvious pipe off vacum leaks etc but nothing is obvious to me?
