997.1 3.8 exhuast size
I have an issue with poor loose fitting of exhaust end tips on aftermarket exhaust and need some measurments.
Does anyone know or can measure the outside diameter of an 997 S (3.8) non PSE exhaust end were the tip will be clamped on?
The exhaust installed on my 997 is measured 58mm. Measured a PSE and is 59mm. Need to know what is the dia of non PSE 3.8 exhaust. If also 59mm it wil explain why my end tip cannot be tightened.
