A/C Woes
So my A/C just up and died - one minute, blowing cold as it always does. Do an oil change, brake fluid bleed, and go for a ride, not blowing cold anymore. Seems rather sudden. Is this how they fail? What are the possibilities? Compressor seals, leaking line, what else? How easy/hard is DIY?
Would a fuse affect how cold the air blowing out of the vents is? I will check, but everything seems to be working fine, except no cold air.
If you think you want to take a stab at it yourself... When turned on does the compressor's electrical clutch engage and cause the compressor to run (this is part of the fuse bit). Yes the inside fan will run and blow air even if the compressor is not engaged.
For about $50 you can get a AC Pro recharge kit (the one with the gauge) at your local auto parts store. This you can use to quickly double check your system for pressure and if low you can use the kit to filler' up (it has some sealant to stop leaks but only small ones) so after the top up your system should work again and if after a day or two and the AC stops blowing cold, well then it is obvious it is a much bigger issue.
It is possible you have damaged a condenser (one in front of each small cooling radiators), a line, or even the evaporator.
BUT if the system has been working trouble free and suddenly just stopped... I got money on the compressor's electrical clutch not engaging either because of a fuse, or the Tech disconnected the wire feed to the clutch and it is not completing the circuit.
Best of luck.
Best of luck.
Thanks guys. since I'm the tech, I know the wire feed to the clutch was not (purposefully) disconnected. I will do the condenser check and the fuse check - hopefully that's it - usually the simple things are all it takes. Not likely there is damage to the front condensers, since I have screens protecting them mounted inside the vents (and they help keep the crud down - just cleaned them out well a month or so ago). I'll check and report back.
Good luck, hope it’s something minor. Mine just stopped blowing cold air one day. Ended up changing the compressor and also discovered a leak in the evaporator which was a complete dash out job. Noticed the new compressor cycling on and off and further investigation revealed the ac control unit was also faulty. $3k and some change and it’s now working like new.
fuse is good (I think - I could not find a fuse chart for my year/model, so I looked at just about every fuse). The compressor and clutch appear to engage properly. I could not tell if the condenser fans came on though.
With engine running and AC on put your hand underneath the forward part of front wheel wells. If fans are running (as they should be) you’ll hear them and feel the exhaust air as it’s pushed through the vents.
OK, I did the fan test, with the car up on lift bars and the wheels off. Fans definitely not running. I looked at the fuse chart (thanks Petza - tucked into the fuse box door), and checked all applicable fuses which were ok. I know there are relays for the fans, but I'm not sure which is which. Does anyone know where to find the relay chart? There aren't that many relays - I think it's the relays tucked up above where the fuse panel is.
As to the fans, would that be enough all by itself to keep the a/c from blowing cold?
Thanks - could it also be bad relays? Seems more than coincidence that both would fail at the same time? Also, do the fans alone cause the a/c to blow warm if they stop working?
I disagree. Before I bite on replacing resistors I'd check for 12V at the fan connectors. You'll need to pull the front wheels and the wheelwell liners to get access to the connectors. Here's a good video on fan issues:
A good shop can put dye in that will identify the leak. If you do a DIY top up then a good shop may refuse to work on it as the diy refrigerant can bugger up their machines
