Need advice on Wheel fitment
Looking around for a set of wheels for my 997.1 C2S. I have the option of going with fully custom built wheels to my specs or getting pre-made wheels specifically built for a 997.
I found a wheel I really love for sale locally (much cheaper than going custom built, obviously) with the following specs:
Front: 19x9.5 +40
Rear: 19x12 +70
Please advise if you think any issues, I know for sure these were specifically made for the widebody models. I am familiar with aggressive wheel fitment and the typical modifications that can to be done (fender roll, camber, spacers, etc.) and would love this wide a wheel.
Pic for reference.
Front: 19x9.5 +40
Rear: 19x12 +70
Pic for reference.
My car is a narrow body (C2S) so should be aggressive vs stock. I just want to know if I can get it to work with normal modifications, not trying to pull fenders or go widebody.
If you want your rear tires to be flush with the fenders, you should get something that pokes out approx 17mm more than the OEM NB wheels. 15mm will look good as well. Wide body wheels (51 offset) on a narrow body car gives you 16mm more than OEM NB sizes which works very nicely.
By the way, I highly recommend you play around with the different options at www.willtheyfit.com
Are you sure you have +30 offset on an 11" wide wheel? With those measurements the wheel will poke out 37mm more when compared to the OEM size for a narrow body car which will cause the tire be outside the fender.
OP, with the measurements you provided, the fronts are too wide at 9.5 inches and will poke out 36.1mm more than the OEM NB wheels with that offset, so they will not fit. The rear wheel will be 15mm closer to the strut and will poke out more only 9.7mm compared to stock NB wheels which is not very good either.
Yes. My car is a WB. Forgot to mention that.
I can tell just by looking at these specs that this was a really aggressive setup for a NB car. It just wouldn't make sense to custom make these specs for a WB car.
No way those fronts will work.
Here's a photo of an 8.5" wide wheel with a 42 offset I test fit onto my 997 C2S and they stuck out beyond the fenders. The ones you're looking at are a full inch wider - that by itself even if they were a 42 offset would add 12.5 more mm to the poke and with an et 40, 2 more so they would be 14.5mm further out than the wheels in this picture.
Optimal front offset on an 8.5" wide wheel on a 997 is et50. That looks like this. If the front wheel is 9.5, you need to add 12 to that offset to maintain the same outer position (et62), but that probably won't clear the inside strut
For cars with coilovers and ride height dialed down a bit, or maybe a degree of camber tossed in the mix, things change quickly. Here is a photo of my car with a total effective offset of 40mm on a 19x8.5.
This is dependent on ride height too. For the average drop, you're spot on.
OP, note that GT3_ISH talks about being at a 40 but it's on an 8.5" wide wheel. The wheels in your post are 9.5 so they would be 12.5mm further out that his setup because of the extra 1" of width, 1/2 of which goes inward and 1/2 of which comes outward.
My car will be on air suspension here within the next 1.5 months. I already have everything on order and just waiting for my custom bag setup to be built.
As of now, here is what I am thinking I will go with as far as specs: 19x8.5 +45 (maybe +42) Front and 19x11 +52
I agree the specs the wheels are currently in are far too aggressive and need to be rebuilt, which I plan on reaching out for the cost (if any).
According to your signature you're a 20" wheel, which also changes how the final outcome looks. The OP is going to be running 19" wheels.
Yours and Petza914's suggestions should keep you close to a happy medium with the car aired up or out IMO.
