Brake pad dust / Powder-Coat experiment
Old 07-26-2018, 05:13 AM
Edgy01
Poseur
Edgy01's Avatar
What is brake dust?
Old 07-26-2018, 11:03 AM
Darkhorse
Darkhorse's Avatar
Default What is brake dust?
Originally Posted by Edgy01
What is brake dust?
Have a look at the front wheels of almost any BMW. Most guys with Porsches fight this battle unless, like you, we have arrived in the promised land of PCCBs.
Old 07-26-2018, 11:05 AM
Petza914
Petza914's Avatar
Received 6,552 Likes on 4,167 Posts
Edgy is being cute - he has PCCBs
Old 07-26-2018, 11:06 AM
Darkhorse
Darkhorse's Avatar
read my whole post
Old 07-26-2018, 11:08 AM
Petza914
Petza914's Avatar
read my whole post
I did - I saw you mentioned PCCBs. Just clarifying for others. PCCBs are noted in his signature too.
Old 07-26-2018, 11:10 AM
Tcc1999
Tcc1999's Avatar
What is brake dust?
Spoken like a true ceramic brake man!
Old 07-26-2018, 11:16 AM
LexVan
LexVan's Avatar
Received 5,407 Likes on 2,514 Posts
Say bye bye to brake dust:
Old 07-26-2018, 11:19 AM
LexVan
LexVan's Avatar
Cleaned wheel with Optimum Gloss Coating (applied fall 2017):
Dirty wheel, with over 2,000 miles, no washes, just OGC and the Armor All topper:
Tcc1999
Tcc1999's Avatar
If you are being scientific, you may also want to also consider the reason why dust is adhering to your rims. The short reason is static electricity (wheel spinning though air generates static electricity which dust “sticks” to; just like rubbing a ballon agianst your hair will result in it sticking to the wall). So, in addition to pads, you may want to research some anti-static compound or treatment for your wheels. Good luck
Old 07-26-2018, 11:47 AM
Petza914
Petza914's Avatar
Originally Posted by Dennis_NL
Deep cleaned wheels first with Monello Non-ferro (Dutch brand). Removes brake-dust and iron particles
Step 2 - deep clean all brake dust with detailing clay
Step 3; applied Poorboys wheel sealant. Brake dust comes off easily with power washer.
After every 3 to 4 washing cycles I apply a thin layer of fresh wax. Works perfect.
That wheel cleaner looks like it goes on kind of green then reacts with the brake dust and turns purply - same thing that Sonax Full Effect does, which is what I use. Wonder if it's the same product rebranded for different countries. Works great though.
I clean with Sonax then apply Armor All Outlast spray after wiping and drying the wheels - just did the Cayenne after our beach trip.
Old 07-27-2018, 06:39 AM
Climarepair.com
Former Sponsor
Climarepair.com's Avatar
Nice work
Old 07-27-2018, 09:49 AM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,562 Likes on 940 Posts
I replaced the right, passenger side, pads, front and rear, with Hawk Performance Ceramic pads. I left the OEM Textar pads on the left side
Do you plan on braking in circles? Sounds pretty dangerous to me.
Peace
Bruce in Philly
Old 07-27-2018, 09:53 AM
Darkhorse
Darkhorse's Avatar
Thanks, that makes sense, but I only set out to see if the Hawk PC pads would produce less dust than stock pads and if so, what color that dust would be. TBH, I did not know about static electricity or Outlast. So, I have learned extra things.
Old 07-27-2018, 09:56 AM
Darkhorse
Darkhorse's Avatar
Peace
Bruce in Philly
I did not expect to feel a difference, but now having driven 180 miles with this configuration, I can feel no difference in the braking performance. Mario Andretti might find a difference at the limit, but me, nope, they're all just brake pads.
Old 07-27-2018, 02:21 PM
Iceter
Iceter's Avatar
It may be too late to do, but it would be interesting to measure the thickness of both pads and rotors before and after your experiment to see which pad would wear faster (you could even extrapolate expected pad life) and whether or not there is a negative impact on rotor life by going to a pad that creates less dust.
Quick Reply: Brake pad dust / Powder-Coat experiment
