I recently purchased my 06 C2S, and one of the “features” was it had full front ppf. Well after owning it a bit, the ppf was driving me nuts. First off it was laser cut, not wrapped edges, so the edges of the film were awful, and it stopped 4” from the top edges of the hood. I also noticed there was definitely a color difference.
So i decided to remove the ppf and go with a ceramic coating. The peeling was fairly easy. The fenders went very well, with very little mess. The nose went well with the exception of the paint coming off along the bottom. I assume it was a repaired spot at some point, but in an easy spot to repair. the hood came off, but left an awful mess of adhesive. I assume from years of sun baking it on. I have several hours into the goo removal, trying several different methods, with ever so slowly gains.
I am to the point that i think i will just have the hood resprayed and let them sand it off. Or plan B is to roll it outside and light the whole damn car on fire. Has anyone else removed the ppf goo with success?
here are a few pics of my hell
Hmmmm I assume you tried the obvious... Hot water and Dawn? I get sap spots of very easily with this. You also try just contacting say 3M customer service and ask them.
I went through this hell with my stone guards that I assume were original to the car and baked in the Texas heat for a decade. There is no easy way, unfortunately. Did you try adhesive remover? That's what wound up working for me although it was very tedious. Spray adhesive remover liberally, use a soft cloth or something with a soft plastic edge to "scrape" the goo, and wipe it away. No paint damage on my fenders from using this method, YMMV, but it will take some time.
Don't light the car on fire... although I bet that adhesive would make a nice accelerant.
Other option is to take it to the pros who install PPF. It might cost a bit, but I bet they can get it off without any paint damage.
I have tried mineral spirits, goo gone, 3m adhesive remover....all work, if i were removing goo from a small decal. On the entire hood, i may no be driving my car until next spring at that rate
I hear ya. Took me 4 hours for two stone guards. Best bet might be a PPF pro shop. The paint underneath should be in fine shape, so I don't recommend trying to sand/re-paint.
Acetone very carefully small spots at a time, it will remove it better than others mentioned. If it has been repainted it could be an issue, try a small spot to test.
A while back I encountered some of the worst sap ever. Tried citrus degreaser, isopropyl, and goo gone. None worked, I was convinced it had fused to the paint. Tried some peanut butter and it came off cleanly after sitting for a moment.
Had the same issue with my headlights - as above, Goo Gone and 3M trim adhesive remover - took a couple of hours just for 2 headlights, can only imagine what you're dealing with
I'm assuming you didn't use a steamer to remove it? To loosen up the left over adhesive, baby oil and water, Goo Gone, good old Plexus or Honda Polish work wonders.
First and foremost, a heat gun is essential to proper removal of PPF or let it stand out in the heat before attempting to peel it off. That’s how professionals do it.
I did use heat to remove the film. The heat helped soften the film, and required less force to pull. Using heat also left behind more adhesive
