Smokin TT
Smokin TT
Just bought my second Turbo, first was a 1986 930 with 32,000 miles on it. My recent investment is an 08 TT with 51 k miles on it. Pristine, all service documented at dealer by previous owner. Upon start up more blue smoke than I want to see. Wish I had access to do a compression check. With other lesser vehicles I have used a high mileage oil additive which really helped eliminate smoke on start up but i just cant bring myself to add anything to the
Mobil 1. Any advise?
How blue are we talking? The Mezger TTs are known to puff out smoke on start-up if the car was driven hard and turned off immediately after, among some other mundane scenarios. The remedy is typically to let it idle for 30 seconds or so before turning it off. The smoke is more on the white end of the spectrum with maybe a subtle blue tint, though, not straight up blue oil clouds.
First thing I'd do is change to a different oil - either Motul xcess or JGR DT40. Many people have noticed reduced consumption when getting away from the Mobil 1. Also, I'm not sure on the 997, but on my TT Cayenne, the crankcase ventilation is tied back into the driver's side intake pipe so that any oil vapor gets run through the engine again for emissions purposes. This oil vapor condenses in the intercooler and needs to be drained every 2 or 3 oil changes or it can get sucked back in and produce smoke, but if that's your issue it would likely do it more than just at start-up. Might be something to check into though.
Back in 2000 when the m96/M97 generation started, puffs of blue smoke on start up were not uncommon (I know, the TT is a different block but the blocks are still flat). It was not the AOS. I found I could make it happen by starting my car and immediately shutting it down... say like checking a gauge or moving the car a few feet.... next morning was a nice large blue cloud. It was described at the time as a very slight pooling of oil in the heads, the natural consequence of a flat engine design (hence the oil scavenge pumps in the heads). Also, it was said, the ring gaps can start to line up over time allowing oil to seep through. All of this was no issue. Was this true? I dunno. It was the working knowledge of the time, and posts about startup puffs were very common.
BTW, I was at the dealer when a sales rep started one up on the showroom floor... the car was brand new.... the entire showroom was blue... everyone jumped up and opened all the doors..... no one said anything. Weird... obviously this was common.
Peace
Bruce in Philly
Peace
Bruce in Philly
Peace
Bruce in Philly
Peace
Bruce in Philly
