Tune for the 997.1?
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/495a9aa8_e11f_4433_9afd_0edb026a95fa_a73ef3aced3e1725bbb1ee60a25070a787b89d19.jpeg)
Fiddling with the idea. Not sure if any are worth there weight. Leaning on fvd or giac. Have the full racing exhaust on 07 997.1 s. Anyone have a good or bad experience to share?
yup, even if you had oustanding quality 93 octane the tuners have admitted to screwing with the throttle control mapping on their na tunes in order to give that perception of increased power. This and cognitive dissonance is why youll hear people report..
"i got tuned by xyz and it really revs faster in the top end"
or
"i got tuned by abc in order to smooth out that torque dip and now it pulls harder to redline"
The reality is we can log your car right now and i guarantee your pulling a bunch of timing on that crap 91 octane. Youre not going to be tuning in much of any more power on a car that is already maxed on its octane.... and im sure porsche already tunes for mbt.
mike
or
mike
Question: I have access to 91, 94, 96,98, and 101 Octane close to my house. What is the sweet spot on an otherwise stock car? and how quickly can the ECU adapt to the better quality fuel? 91 is the highest 99.9% of the gas stations we get out here.
I haven't extensively logged the porsche for timing improvement since its somewhat moot for me as i have no intention of putting race gas in it but i wouldnt be surprised if the timing tables are set up to be able to take advantage of up to around 95 octane or so. After that you do need a dedicated race file but again somewhat unnecessary on the naturally aspirated porsche as most of us arent trying to break 1/4 mile records.
Meaning the extra 20hp from an extra 5 degrees of timing isnt usually worth the cost of 10 dollar per gallon 100 octane on a daily basis and if you were just doing it for a drag strip day well a run of the mill 25k dollar audi s4 with a tune will clean the track with a 997s embarrassingly
Ok then. Looks like no tune it is. Just ripping around as daily and backroads anyways. Lots of these mods just don’t carry there weight in the end by the sounds of it. No plenum no intake no tune no light weight flywheel. Full awe racing exhaust is all I have and will have. Get a faster car to get more tickets I guess that’s an option.
thanks for the input
Wait! Gotta say... My experience with a tune was fantastic! I went with the Mygenius thru Fabspeed. After a few engine and exhaust mods, having the tune absolutely improved my driving experience. The torque band shifted to lower rpm's and acceleration and throttle response all improved. Drivers here will argue about it all day long, but in the end it's what you perceive and feel that makes it rock. I would do it again without hesitation.
Phase 2 - I'm set to have a new designed valved-exhaust system installed soon by Soul Performance Products. As soon as I get back from the check ride, I'll get the RETUNE ordered to take advantage of the open pipes.
its not really something to argue about. Your acceleration either objectively improved by x amount or it didnt right.
the subjective is just that which is from manipulating throttle maps. This has a huge impact on feel and none on actual max acceleration. I wasnt meaning to minimize that but it can be accomplished with a cheap throttle manipulator.
mike
Have been following this thread with some interest. My car is X51 so I’m wary of any aftermarket tune. Being too paranoid?
I’m going to order an FVD/M&M PSE specific header and catted u-pipe set up soon. One of my concerns is that I do not want to load a tune onto the car. I discussed directly with M&M and they state that their hardware should not trigger any CELs.
I would trust m&m and fvd to advise if they require a tune but theres no reason an exhaust upgrade should. Even if you got a cat inefficiency cel that has nothing to do with performance. tuning out post cat o2 sensor sensitivity is nice for removing a cel but thats it.
So the question is if the exhaust changes is so dramatically affecting certain fueling or timing tables that the ecu's pretty substantial ability to adapt to performance changes isnt able to do so.
2 ways to determine that. See if fvd has any first hand datalogs to share with you addressing exactly that or just take the datalogs yourself. Do some baseine logs now and then compare after if fvd cant provide the data for you
either way i assume you plan on doing some controlled condition acceleration testing before and after as well so you can see whats what with the mods. Do ypu hsve a dragy or st for testing? You can use an nt510 or dura or whatever for logging afr, timing, misfires, torque, fuel trims, for a good start.
mike
mike
mike
mike
Also, for the controlled testing. Take it to a drag strip with actual timing equipment, not a GPS based performance meter. I could list off 1000 reasons why, but we'll just stick to the surface being more consistent and safety.
