Sticky radio knobs
I just followed the advice of Bruce: https://rennlist.com/forums/997-foru...l#post14571149
and a number of folks report that the cleaning method removes the soft rubber and leaves them feeling hard and plasticky, not tactile.
That's a good question. I thought they would have changed it, but I don't know. Maybe mine will get sticky over time, but not yet anyway. Cleaning might have worked, but no question some material would have had to come off. I just went ahead and spent the 60 bucks.
I don't think MaCarbon sells them separately? Maybe they do, ... anyway, I generally stick with OEM unless it's a significant improvement (like wheels). Just my personal preference to keep it stock/OEM.
I bought them from MaCarbon and they were OEM, just thought I would get them with my new switches and compare to my cleaned ones, figured what the heck for $26, tax included. My cleaned ones looked just as good so I returned them with my core switch returns, no problem. Like I said about $26 all in and OEM..
https://www.suncoastparts.com/produc...M9971KNOB.html
Unless I am missing something on the Macarbon site?
I believe you can only get them on MaCarbon if you buy the whole setup, and I only see Gen1, not 997.2. So it's $26 if you spend the other $185 and return your core, and OEM 997.1 radio buttons are only $24 at Suncoast...
Definitely carried over. For some reason, the 997.2 ***** cost ~2.5 times more. Maybe it's the 3 parts vs. just one in the 997.1. Well, enough said on the topic. Worth fixing one way or the other.
I have had the sticky **** problem on both 996 and 997.2. It's an easy job to clean off the sticky coating with alcohol and re-coat with Plasti Dip spray. There are multiple You Tube videos out there showing how to do it.
I have the sticky buttons in the club coupe and will get around to replacing.
But, thats pretty minor league, compared to a ferrari. They’re infamous for sticky buttons and cost most of $2K to replace
This:
Remove ***** first, they just pull off. Don't keep wiping after the goo is gone. Keep using new parts of the rag, I used old clean t shirt.
Perfect results. Climate control rockers are a different story.
After about an hour of searching, I finally located it (wedged between the driver's seat track and the center console hump. Had to remove the driver's seat to get it. (When I dropped it, it hit the center console shelf and bounced.)
And another note about those screws - If you happen to lose one - good luck getting a replacement. When I dropped mine (and thought I lost it) I contacted Becker to inquire about getting one. Their comment was "we don't supply those items as separate for-sale components..."
Bob in NY (07-31-2020)
Can you share the technique to remove them? I’m guessing you pride out the center cap, and from there you can see that screw? TIA...
