First Impressions - GT3 shifter in my 997.2 Carrera
Old 05-23-2018, 08:20 PM
nwGTS
nwGTS's Avatar
Originally Posted by workhurts
Keep in mind, a Fister D exhaust can be resold or will be worth something to an enthusiast. A muffler welded together by some random person less so. So, if it's under a $200 diff, go with Fister.
I'll second the question of replacing the plastic in the SSK. Anyone done that?
https://rennlist.com/forums/997-foru...l#post15028092
Old 05-23-2018, 09:48 PM
workhurts
workhurts's Avatar
Thanks. That's what I get for skim reading.
Old 05-24-2018, 01:35 AM
saabin
saabin's Avatar
I've considered the SSK mod before but have never got around to it.. maybe some day..
Swing, are you a member of the Mav region of PCA? We are a pretty active group here in N Texas..
Old 05-24-2018, 01:39 AM
nwGTS
nwGTS's Avatar
readinghurts
Old 05-24-2018, 03:53 AM
alex911s
Man of Many Porsches
alex911s's Avatar
Originally Posted by swingwing
I was impressed with the quality of welding and the ceramic coating. To me the exhaust note is just right. With the $550 core refund I thought it was a good purchase.
New mufflers ready to go up and in.
Originally Posted by ATSR
Unless you know someone that can weld as well as the guys that make the Fisters, then they are definitely worth every penny.
Cool thanks guys.. Carnewal been doing that for years they have a Vendor in the US now CantrellMotorsport unlike before
But will try out Fister they are local to me which is great!....and I see the quality work...
Old 05-24-2018, 04:47 AM
El Dario Loco
El Dario Loco's Avatar
I recently upgraded my OEM SSK with the FF kit. Also adjusted the cables with the aligment tool and changed to a FF billet shifter **** with the longer shaft. Really happy with the result. I know the longer shaft defeats the purpose of the SSK somewhat but the improved ergonomics makes up for it.
Old 05-30-2018, 02:04 AM
WantA997
WantA997's Avatar
Originally Posted by SoCal C2S
If you likey the GT3 shifter, you’ll flip out if you upgrade to the Numeric (with Numeric cables)....it's a whole other level of precision.
You'll flip out at how bad they are.
Numeric cables = cancer. Avoid.
Old 05-30-2018, 09:38 AM
love2drive
love2drive's Avatar
I upgraded my GTS manual to the OEM SSK and noticed a marked improvement in shift precision. I always wondered if the OEM SSK plastic bushings can be replaced with the GT3 metal bushings. If so, is it an easy DIY?
Your help is much appreciated.
Originally Posted by nwGTS
Those are some solid mods. I bet the Fisters sound awesome.
Some info on the shifter unit:
OEM Carrera and GT3 shifters are exactly the same except for metal bushings. Only OEM SSK has shorter throw and plastic bushings:
https://rennlist.com/forums/996-foru...ml#post8137281
Nothing wrong with going OEM for reliability. For those comfortable with the DIY, you can make you own GT3 shifter out of a Carrera unit with the exact same metal bushings for $65:
https://phenixengineering.com/shop/p...t-bushing-kit/
Old 05-30-2018, 11:38 AM
nwGTS
nwGTS's Avatar
yes, super easy
These guys make it way too hard on themselves.
Don't use a screwdriver or a knife to cut the tabs (wtf). Use a small chisel and hammer.
Don't use a needle nose pliers on the end to rotate the plastic bushing (wtf). Use a channel lock around the whole outer part of the bushing and turn like you would a pipe. Way more leverage.
This should not take longer than 10-15 min to do.
TrofeoCollection (11-07-2023)
Old 05-30-2018, 11:54 AM
El Dario Loco
+ 1 on the chisel and hammer part. Takes forever otherwise! And using needle nose pliers to turn a round plastic thing that is fitted tightly is just stupid..
Oh, and wear eye protection when cutting the plastic tabs. Those suckers ricochet like bullets.
Old 05-30-2018, 04:31 PM
workhurts
workhurts's Avatar
readinghurts
Seriously. It's getting worse. I blame cell phones. It's bad across the board, employees of all levels, if it's not a text, subject line to an email or a very very very short powerpoint then nothing registers.
Old 05-30-2018, 05:50 PM
user 72902
user 72902's Avatar
+1
Old 05-30-2018, 09:31 PM
awrryan
awrryan's Avatar
Agreed. Second to none.
Old 05-30-2018, 10:10 PM
nwGTS
nwGTS's Avatar
If anyone wants an unused unopened set of these Phenix bushings I have them ready to ship. $50 shipped to conus. PM me.
Old 09-15-2021, 07:03 PM
STALKER99
STALKER99's Avatar
Does anyone know the actual Porsche code for the shifter and not the SKU part number from Suncoast.
Trying to find the right part for my 997.2 GTS, don’t want the SSK but prefer the GT3 shifter with the metal bushings. My local dealer can’t find it in their system.
Thanks in advance.
Quick Reply: First Impressions - GT3 shifter in my 997.2 Carrera
