Video review of the Foxwell NT510 with Porsche software...
#31
floatingkiwi... I guess so... haven’t heard that any of the other ones have that capability....
myw (04-25-2020)
#34
I recently picked up the NT520 for use on my 997.1. It appears to be unable to reset the service interval on the 997.1 even with the latest software update. I have tried the following programming options so far:
When checking the over-rev count on the DME, they appear to match a durametric report that was recently run; but on the same report there is a total mileage report that is not matching the total mileage I would expect the car to report. Can someone else check this field and let me know if the total mileage field matches your ODO?
I have fully mapped out the coding options menu hierarchy since the menu system is a bit tedious to use. Update: posted in #38
If anyone is in the SoCal area and wants to swing by and try any settings please let me know, or if there are any settings in the device you would like me to test and report back let me know and I will do my best to test and report.
- Successfully programmed the comfort widows up/down from the fob/remote. Doesn't appear that sunroof is possible with this device.
- Successfully changed the side markers to turn signals
- Successfully converted retractable spoiler to fixed
- Sucessfully enabled horn honk on remote locking.
- Tried to enable one touch passenger window up. Only works after window is halfway up, which is how it worked before coding. Anyone had any luck getting this to work at any window level?
- Turn on sport chrono illumination when not in use
#37
I'm going to post the coding hierarchy in the post below. Please note that there may be missing modules due to my car not having all the modules (this is from a 2006 c2s MT), if you have any of the missing modules and wish to contribute please do so.
Edit: I've tried twice to post the hierarchy and my post is apparently "pending moderator approval". So hopefully it will appear soon.
#38
- DME
- customer specific setting
- cruise control
- PDK (tiptronic)
- (no coms)
- PSM
- (Function terminated)
- PAS
- basic coding
- country code
- vehicle type
- Transmission type
- central locking system
- relocking time start
- alarm system deactivation
- reaction time key button 2 and 3
- central locking opens with lid opening
- comfort functions
- comfort via radio remote control
- comfort function window
- convertible top function
- door and window comfort function
- Key settings (1-4 individually listed)
- Selective opening
- locking on ignition on
- locking when speed > 5 km/hr
- relocking time radio remote central unlock
- relocking time after lid operation
- basic coding
- Gateway
- vehicle variants
- Control arm
- vehicle model
- vehicle type
- required control module lists
- vehicle electrical system
- rear
- drivers door
- passenger doos
- convertible top
- targa roof
- memory seat adjustment
- front
- tire pressure monitoring system
- steering wheel electronics
- gateway
- air conditioning control
- aws
- PAS
- instrument cluster
- CDR
- PCM
- Chronometer
- DME
- tiptronic
- PAS
- PSM
- Steering Angle sensor
- PASM
- POSIP
- CD Changer
- External bose amp
- phone
- sat radio
- dvd driver
- tv tuner
- navigation
- SBS
- sound exhaust
- pas max
- headlight beam adjustment
- seat heating
- on board computer
- speed control system
- multi-func. steering wheel
- sunroof
- park assist
- vehicle variants
- AWS
- (selected function not supported)
- Convertible top
- (no coms)
- cornering light
- (no coms)
- drivers door
- customer specific settings
- memory via radio
- mirror memory function
- lock with safe function
- synchronized mirror adjustment
- mirror lowering
- close comfort
- open comfort
- inner door handle when driving
- manual transmission
- vehicle model
- vehicle type
- ambient light
- window short stroke by lug comp operation
- comfort locking via key
- comfort opening via key
- rattle prevention
- door entry light
- inner door handle
- Front
- Customer specific settings
- individual memory
- side marker or flasher repeater
- switch off fog light for high beam
- home function with
- HBA steering angle sensor
- front lid emergency release
- daytime driving light is mandatory
- front direction indicator light type
- headlight type
- Park assistant
- (no coms)
- Passenger door
- memory via radio
- mirror lowering
- close comfort
- open comfort
- vehicle model
- vehicle type
- ambient light
- rattle prevention
- door entry light
- inner door handle
- POSIP
- drivers thorax airbag
- passenger thorax airbag
- head airbag drivers side
- head airbag passenger side
- drivers side front airbag stage 1
- passenger side front airbag stage 1
- drivers side front airbag stage 2
- passenger side front airbag stage 2
- pretensioner for drivers seatbelt
- pretensioner for passenger seatbelt
- drivers side sensor
- passenger side sensor
- drivers front sensor
- passenger front sensor
- aws
- belt buckle drivers side
- belt buckle passenger side
- right/left hand drive
- key switch passenger airbag off
- PTM
- (no coms)
- Rear
- vehicle type
- country code
- transmission
- slide/tilt roof
- spoiler
- rear wiper
- auto rear wiper in reverse
- alarm system
- inclination sensor
- acoustic alarm output
- seat memory
- (no coms)
- steering column switch
- tiptronic
- multifunction or sport/launch display
- headlight washing system
- push-to-talk
- rear wiper system
- targa roof
- (no coms)
- TPM
- (no coms)
- unit support
- (no coms)
- vehicle elec systems
- vehicle type
- individual memory
- left seat heater
- right seat heater
- diffuser lens washing
- heated rear window and/or mirror
- rain sensor
- rear spoiler
- sport
- rear lid interior light
- garage door opener
- garage door opener county coding
#40
bhvrdr can that spoiler setting be changed?
#41
The options for the rear spoiler are "fixed" or "retractable". I just tested this on 997.1 and by changing this to "fixed" my spoiler remained the the position it was prior to the coding and the spoiler button became non-functional. I did not road test but this appears to remove the spoiler actuation completely. I've updated my post #34 above with these results.
#43
Sure, over revs are located at: Porsche>(model selection)>Diagnosis>Control Units>DME>Special Function>Vehicle Data. The over revs are are located at the top of that report. The last item on that report is "Total Distance", can you let me know if that figure matches your odometer? Hope that helps.
#44
