997 gearbox drain plug
I expected to find the drain plug fitment a 10mm hex socket. Surprise! On my car it is a very large bolt head. Does anyone know the correct size? I can't get it off to go buy a socket 😣
Not sure if you have .1 or .2. Mine is a .1 and it was fairly easy following this DIY. Just make sure you use a tarp. Gear oil stinks.
https://rennlist.com/forums/997-foru...il-change.html
