What would prevent me from adding a set of aftermarket (KW) 997TT coilovers on a 997.2S?
I know the fronts are differently designed on AWD cars, but is there anything that could be done to make the parts fit? The rears I see are close, but with different spring rates.
I believe the front top mounts are also different between the different models. C2 ,c2s ate one type, turbo and c4 / c4s another, and gt2 / gt3 a third type. Spring diameter and shock valving are also different, at least they are with Bilsteins. If you changed to a monoball top mount, you might be able to make them work, like a Tarett one. Ira at Tarett would know.
