Porsche custom love seat and 997 seat wiring question
I designed this with a local shop and had them build for me.
The only issue that I'm running into is I can't get the drivers seat to work unless I hook directly to the motor. Since the drivers seat has more wiring underneath and I don't have a wiring diagram I'm not sure what wire I need to hook to in order to make it work.
Can someone point me in the right direction or send me the wiring diagram? These came out of a 2005-6 911 cabrio I believe.
Thanks for helping!!
Very cool.
Here you go. Follow the colored battery terminals to the contacts in the seat box. Brown is ground and white is 12v +
This one os a passenger seat but should be the same.
Super cool. You did remove the airbags right?
I did find the passenger side very easy. The drivers side had memory so there is an additional box and from what I've heard I will need to power that box up as well to make it work.
a friend who is a porsche tech told me pin 30 and 31 were ground and power but I can't locate what is 30 and 31. Any ideas here since the drivers has memory?
Regarding the airbags, I'm not connecting those wires or sensors. I don't want to remove if these ever find themselves in another vehicle. If I don't connect them and completely avoid the connections I shouldn't have a concern correct?
