I have one in my 997S. It Just fits standing up at the back of the cavity but you need a bungy strap hooked across to the plastic as otherwise the lid won’t close. Negative is that you loose valuable space for two suitcases for trips. BTW, picked it up used on one of the forums for $100.
Reason: adding info
I don't believe you're supposed to use the space saver in the rear. You're supposed to move a good front tire to the back, and then put the space saver in the front.
