bleed coling system 997
Old Jan 18, 2018 | 03:59 PM
D_May's Avatar
D_May
Default bleed coling system 997
bleed cooling system 997
Old Jan 18, 2018 | 06:17 PM
docdrs's Avatar
docdrs
definitely
Old Jan 19, 2018 | 08:15 AM
Petza914's Avatar
Petza914
Better than a bleed is to use an Airlift and your compressor to do a vacuum fill. Remember 50/50 mix with Porsche pink coolant and distilled water. If you've already filled it and need to bleed, lift up the little metal clip on the coolant tank and drive around gently in your neighborhood, checking it frequently. Let it cool down before opening the cap to add more. Once it seems fairly stable, check it each day for a few days.
