Add music streaming for $18
This is my first Porsche. Here's what I read in the 2009 Technik Introduction book that came from PO. "The new 911 models are equipped with...PCM 3.0. There are two types of PCM available - a Low or High system. The High system also includes a hard drive, navigation system and voice control (SDS)."
From window sticker I see my car has options Bluetooth Phone Interface, Bose Sound Package and the Universal Audio Interface that you see pictured. No Nav, CD changer or Voice so I'm assuming I've got the Low system.
I installed mine ... worked great, but the phone didn't pair to the car's Bluetooth so music only. I changed the Waze output setting and that played through the car nicely. Need to work on the pairing defaults. I suspect the phone issue can be solved.
Android Note 5 FWIW.
Just an update ... the PCM phone interface shut off the audio. I adjusted this in the phone's settings menu and all is fine. The unit shuts off if the phone is not seen for ten minutes, so you need to physically turn it off and back on to pair.
