Overheat ?
At idle the oil temp slowly climbed to just below 225 when the water temp started rising above 176.
Kind of makes me wonder how hot it is at different locations at idle with one fan out. Didn't want to operate it further once I was sure both were steadily heading north.
Wonder if Porsche was actually smart enough to allow the water gauge to show elevated temps (even though its not an accurate number) when need be?
For your coolant (water/EGW) to go up like that is a bit concerning. I've only seen my water temp go up two times. Once,--when the serpentine belt failed and I was quickly nursing it home, and again, when it was about 117 degrees outside one afternoon in Las Vegas. Sadly, Porsche elected to dumb down the coolant temperature gauge to the point that it is essentially useless. No trending capability at all. It goes from 'ho hum' to "OMG!" in seconds. There is nothing in between. That is a significant disservice to normal people. I wish Porsche would (or maybe a clever IT guy) would rewrite the code that controls that.
Update:
left it at my inde one day this week for diagnosis.
Could not activate either fan with computer diagnostics tool (Ipad); nor by turning on the A/C.
Diagnosed all the relays, etc and were functioning as they should.
Accesses the fans and nothing. Apply power directly to the fans and they work. Continue playing with everything and system is now working.
So now I may have an intermittent gremlin or not. I may try to reproduce the overheat next time I get home in the driveway. Doubt both fans had an intermittent issue. Perhaps it was the bitter cold we had last month.
Summer will definitely tell. At least it only cost me $300.
Maybe this has something to do with my sound sytem's silence when its below freezing outside.
User
The power to the radiator fans is supplied by a fan control unit in the front section of the passenger side front fender liner. The fan speeds are infinitely variable by this control unit. If anything in the system is likely to be intermittent I would suspect the control unit is most likely your problem.
Agreed. It checked out fine.
Interestingly - I learned that if one fan goes out it actually runs the other fan faster. maybe those p-car engineers know what they are doing after all. Ha.
Guess I could just replace it if the symptoms return.
