Engine cover release wire
Old Jan 7, 2018 | 11:53 PM
ColoradoMark's Avatar
ColoradoMark
Default Engine cover release wire
We changed out my spark plugs, put in new Fisters and Fabspeed crossover pipes this weekend. There is a cable under the driver side taillight that releases the engine compartment lid.
what’s the point? To get the taillight out the engine compartment lid needs to be open. What am I missing?
At least the one in front makes some sense, even though it is a PITA to get to.
Old Jan 8, 2018 | 01:10 AM
lowpue's Avatar
lowpue
You use a tool that slides between the taillight and bumper, hook the loop and it pops open. Make sure you lay it under the taillight so you can do that.
Old Jan 8, 2018 | 07:41 AM
Presto's Avatar
Presto
Anyone got a picture how exactly this release wire is laid out under the tail light? Mine is just lying loose in the engine bay near the left engine mount.
Old Jan 8, 2018 | 07:52 AM
mike cap's Avatar
mike cap
The engine release wire can be easily rerouted to behind the rear license plate and taped in place. If you do this all you need to access it is a phillips head screwdriver. It pulls and works fine from this location and angle and you won’t have to fish for it or scratch up your car with a coat hanger.
Old Jan 8, 2018 | 09:40 AM
Petza914's Avatar
Petza914
I extended my wire with a metal wire and brought it out through the gap where the heat shields mate. Now I can access it by reaching up under the car if needed.
