Which torque for center lock wheels?
I have a 2011 GTS with center lock wheels which is driven only on streets, no tracking. I have seen two torque specifications for the wheels. 370 ft/lbs or 440 fr/lbs. Which is applicable?
For track use centerlock torque is now 600nm/444 ftlb
Seems to be more info in the GT3 forum.
https://rennlist.com/forums/997-gt2-...read-this.html
ZMC-ZH (04-01-2023)
My 2011 GTS manual included this torque. Earlier model years had a lower torque that, according to the 4/1/13 letter, could result in cracked hubs during track use.
You'll need 450 ft-lbs to put center locks back on.
Make sure the locking mechanism is all the way out after you're done. Only then will you be sure that the wheel is locked.
Here's a link of a brake job I did for my 2012 GTS. It shows which torque wrench I recommend.
https://rennlist.com/forums/997-foru...997-2-gts.html
Good Luck
Good Luck
