@Steve 911 Your video was fantastic. I followed it exactly and it went smoothly. Took about two hours for the first one, then about 45min for the subsequent corners once I got more comfortable.
Thanks to Josh at @Meraki Autoworks for getting me the best price in the USA for the coilovers. Great service! Support your Rennlist sponsors everyone!
Once everything was in, I put each corner under load with the jack (car was on jack stands) and torqued up to spec. Zero creaks, groans or knocks from the suspension so far, a little bit more NVH in the cabin but this is strictly my fun car as I ride my bicycle to work.
The Foxwell NT530 made coding out the PASM straightforward, no errors on start-up.
Went and got the alignment today, I am really impressed with how the car rides. It was only a few miles there and back, but a few freeway interchanges and on-ramps. Looking forward to playing a bit more with the stiffness settings and perhaps height. The wheels are tucked in a bit now so I will get them back to flush with some spacers. Already have a stud conversion done.
Next up, possibly Numeric shifter, cables and gearbox oil change. Also considering replacing water-pump and coolant expansion tank for preventative maintenance coming into summer.
Great write up and thank you!
Car looks great..
-Josh
__________________ Your #1 Dealer for Aftermarket Performance Products
BC Forged / Soul Performance / Akrapovic / Bilstein / HRE / AL13 / CSF + more Orange County, CA Email: info@merakiautoworks.com Text/Call: 213 394 2886 Website:www.MerakiAutoworks.com
Thanks for creating this video tutorial, I usually had a professional do my suspension install for my previous cars but I thought I'll tackle this on my own. Install went great and took it out for a test drive and everything seems good. I'll drive it around for a couple of miles to let the coilovers settle in before I take it to a wheel alignment shop. Also, I was able to disable the PASM error using the Foxwell NT510
I am in the market for coilovers , narrowed it down to :
BC or Fortune Auto - has anyone compared these side by side. There is about $500 premium from Fortune Auto but they are easily rebuild-able. Any insight will help.
Glad it helped out! It's also helpful to know that the NT510 will work for coding on this.
Hi - for Steve and DocR, with the current height that you have, how much thread do you still have below the spring in the front? I’m trying to see if these coilovers will take a set of Stanceparts air cups but I need at least 30mm of room to accommodate the additional height of the air cups. Would you say you still have that much thread left? 30mm is just over 1”.
