spacers without lowering?
Old 12-12-2017, 04:07 PM
shekmark
shekmark's Avatar
Default spacers without lowering?
I have a 2010 C4S with PASM. Would it look weird to put wheel spacers without lowering car? Also...is my car already lower than a base model?
Old 12-12-2017, 04:43 PM
myw
myw's Avatar
you're 10mm lower then base c4. I've put spacers without lowering.
Old 12-12-2017, 07:22 PM
docdrs
docdrs's Avatar
I have spacers without lowering on my 11 C4S
Old 12-12-2017, 07:48 PM
Appraiser
Appraiser's Avatar
I have 7 mm and 15 mm spacers at stock C2 height... think 4x4! But certainly looks prettier with spacers than without.
Old 12-12-2017, 08:18 PM
Skwerl
Skwerl's Avatar
Doesn't look weird, it looks a lot better IMO.
Old 12-13-2017, 12:35 PM
kcheves
kcheves's Avatar
My car came from the factory not lowered, with spacers. But they are just 5mm all around.
Old 12-13-2017, 01:59 PM
shekmark
shekmark's Avatar
Mine has the factory 5mm spacers as well. It was an option. doesn't seem to make much difference so I wonder why Porsche bothers. I will go either 15 all around or something similar like 12/15 or 15/18 ECS brand. I may order their trial kit where you can try on different sizes before purchasing.
Old 12-13-2017, 02:07 PM
Skwerl
Skwerl's Avatar
I have 8/15 on a Turbo (widebody with PASM, unlowered, like your C4S) and it looks just right to me, maybe even 1mm too wide.
Old 05-03-2018, 11:28 PM
rw229
rw229's Avatar
Old 05-04-2018, 01:02 AM
quickxotica
quickxotica's Avatar
Similar setup: stock 997.2 SPASM ride height, with factory 5mm spacers all around. Very subtle before and after difference with the spacers, but I like it.
Before:
After 5mm spacer:
After:
Not the best pics, sorry. But they are all I’ve got so far.
Old 05-04-2018, 02:22 AM
golfnutintib
golfnutintib's Avatar
stock wheels on pasm car w spacers
Old 05-04-2018, 02:43 AM
rw229
rw229's Avatar
Looks good. 15 snd 7 or other?
Old 05-04-2018, 06:47 AM
bhvrdr
bhvrdr's Avatar
that looks like a sport pasm car not just pasm right? My pasm sits significantly higher
mike
Old 05-04-2018, 07:25 AM
andy2
andy2's Avatar
PASM 4x5mm OEM spacers
Öhlins R&T (-2,5mm) 4x5mm spacers
Old 05-04-2018, 07:45 AM
Swift17
Swift17's Avatar
Default This is the look I want - spacer help
I have a 2006 Silver C4 and just bought a set of 2007 (7.5k miles) OEM Turbo wheels - before I install I am thinking 8mm fronts and 10mm or 12mm rears -Your thoughts to a novice (stock photo of an S from net attached )
As always, THANKS
EJ
Quick Reply: spacers without lowering?
