Michelin Pilot Sport PS2 vs PS 4S
Old 11-21-2017, 10:06 AM
dougkeen
dougkeen's Avatar
Default Michelin Pilot Sport PS2 vs PS 4S
Sounds like a lot of Rennlisters are running PS2's and I am sure they are great, but does anyone have experience yet with the PS 4S? My tire guy told me they are basically the next generation of PS 2, should be better, and i should go with them in the event i need one replaced in the future, the PS 2's may be hard to find because Michelin won't be producing them any more.
Just wondering if anyone is running them yet and what is their experience? Stiffness. Grip. Road noise. Wet traction. Hydro plane. Wear rate.
Etc.
Old 11-21-2017, 10:47 AM
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
I would say many RL are running PSS, not PS2s, since the Super Sports replaced the PS2s.
In general, I'd say Michellin are great tires, but as they have made them last longer (PSS and the new PS4S), less expensive, and gave them better wet traction performance, they have lost some of their dry traction performance (like the PS2).
Here's some recent info:
https://rennlist.com/forums/997-foru...m-reviews.html
https://rennlist.com/forums/991/1033...chelin-4s.html
Old 11-21-2017, 11:22 AM
cosm3os
cosm3os's Avatar
4S is fantastic in all conditions--street, wet, and track.
Old 11-21-2017, 11:47 AM
Crester
Crester's Avatar
Pilot Sport 4S is the new version of the Pilot Super Sport... not the PS2.
Old 11-21-2017, 02:12 PM
voiceprint1
voiceprint1's Avatar
Do the folks running the 4S use factory air pressures or do you have to tweak it to get good results?
Old 11-21-2017, 02:14 PM
LexVan
LexVan's Avatar
Most RLs don't run factory spec air pressures on any tires. Too high.
Old 11-21-2017, 03:09 PM
96Tiger
96Tiger's Avatar
I currently have PS2s and will be replacing them with PS4Ss as soon as they wear out.
Old 11-21-2017, 05:47 PM
rodH
rodH's Avatar
this is kind of a technicality, Esp since in most of the world the PSS was called the PS3, so yes, the 4S is a new version of the PS2, but most recently it is what replaced the PSS/PS3.
Old 11-21-2017, 05:53 PM
alexb76
alexb76's Avatar
I haven't tried PS4, but MPSS... my experience has been that MPSS improved ride, wet, and wear over PS2, BUT it actually lost dry performance! PS2 essentially worked a little like track tires, it had little grip if cold and then immense grip when hot and on track. MPSS has a broader range of temps that it works great, and so much better in Wet, but doesn't have the ultimate grip of PS2 in dry.
Now, if PS4 goes in the same direction, I assume it'd be similarly behaving to MPSS. So, I'd go for those as overall street tires, but if price were the same and I mostly did dry/track, I may stick to PS2.
Old 11-21-2017, 05:54 PM
alexb76
alexb76's Avatar
100% agreed!
Old 11-21-2017, 07:46 PM
lowbee
lowbee's Avatar
Originally Posted by alexb76
......but if price were the same and I mostly did dry/track, I may stick to PS2.
I am curious to know which street tire is as good or better in the dry than PS2 ....also have similar or less noise level ..... any ideas ?
Old 11-21-2017, 08:09 PM
voiceprint1
So if your running 19 in tires, setting the PSI lower is better than the factory settings? I don't want to open any worm can, but when I asked my indy he simply said, why would you not want to run stock PSI?
Old 11-21-2017, 08:19 PM
LexVan
LexVan's Avatar
What are you currently using? 34/38 would be a decent starting point. Adjust as you see needed.
Old 11-22-2017, 12:34 AM
Lvt19672
Lvt19672's Avatar
I'm currently running 33/37 and feel that the ride is still a little firm.
Old 11-22-2017, 01:12 AM
love2drive
love2drive's Avatar
For my 2012 GTS, I'm running PSS and like them better than my previous PS2s.
I'll probably go with PS4S next.
Quick Reply: Michelin Pilot Sport PS2 vs PS 4S
