Stripped oil plug
#31
I have one too, and by the way, it always collects a bit of ferritic material, but i think the effect is cosmetic. A good quality filter does a more comprehensive job.
In addition, cheap magnets lose part of their magnetism when heated, sometimes already at 80°C/176°F. So a lot of spook ;-)
#32
'12 997 C2S. What's the chance JB Weld would work to "weld" a throw away socket on to get drain plug off? I've tried the punch method (failed), would rather not try Dremel as I'm afraid I'd cut oil pan.
I have a LN Engineering plug to replace, just need to get this old one off without damaging other parts. Never had this problem with my '09. I did spray some PB Plaster just in case there is gunk/rust causing the plug to seize up.
#33
The hell with torque recommendations for a lousy oil drain plug .... After doing this for 40+ yrs ....I follow the same procedure on all drain bolts .... Turn plug until it makes contact with the crush washer ....then slowly turn until you feel the crush washer crush .....then give it a LITTLE more of a crank for good measure ...That's it you are done ... Never had one get loose or had one cause and issue . Same procedure can be followed when installing an oil filter. Keep in mind after a few heat cycles these things will also tighten up a little by nature and this is what causes the issues when attempting to remove them later.
When it comes to torque values and crucial when building and engine etc ....In many cases the values for general re&re of external components can be excessive or too little .
Example: I just changed my water pump and torqued to the recommended 7.5lbs which I thought when installing felt too loose ? against my better judgement I went with the gospel.... I start the car after the job and the pump was slowly dipping .. I get back underneath and bump the torque to 10lbs .....No more drip !
#34
#35
8x57IRS (02-12-2022)
ManoTexas (02-14-2022)
#41
Mine on a 981 Cayman. Punch and hammer.
At first, I asked nicely and it said "nope".
Then, I asked firmly but politely, still "no".
Then, I asked with intensity, "no" again.
Then, I said if you don't let loose, I am going to punch the ****ing **** out of you.
And it finally, agreed.
Wayne Smith (02-13-2022)
#42
I gave up oil plugs 2 years ago when homeless issue started here in Seattle. Now I hire skinny druggy strapped to underside who sticks his finger in drain plug hole.
I'm able to get much more accurate oil temperature readings as well as updates on if any metal particulants when I inspect his fingernail every few weeks.
The following 2 users liked this post by groovzilla:
ManoTexas (02-14-2022),
matttheboatman (02-14-2022)
