Spacers
Old 11-05-2017, 02:43 PM
  #31
myw
myw's Avatar
Originally Posted by shekmark
I meant 21mm spacer . Seems like I’m reading about guys with 15mm spacers saying they are not enough so I thought 21’s. I already have 5mm. I am going to do the straight edge test. I have not done that yet.
21mm will push beyond the fender. 15m is max. it's the 7mm front that isnt enough for a typical oem 8 inch front wheel
  #32
myw
myw's Avatar
15mmF + 15mmR - oem pasm suspension.
Old 11-05-2017, 03:00 PM
  #33
shekmark
shekmark's Avatar
Great info. Thanks. That’s just what I needed to see!
Old 11-05-2017, 03:23 PM
  #34
Mumbles
Mumbles's Avatar
Sheeez lokin good there myw.......
Old 11-06-2017, 01:31 PM
  #35
myw
myw's Avatar
thanks neil! a few more mods when i get around to it and all done.
Old 11-14-2017, 10:37 AM
  #36
Falcondrivr
Falcondrivr's Avatar
See my post above. I’m running 20mm all 4 corners and it sits flush with stock 4S lobsters.
Old 11-14-2017, 11:45 AM
  #37
LISsailor
LISsailor's Avatar
were these on the build sheet as an option?
if they *should* be 19x8+57F 19x11+51R (standard 997.2 WB width and offset). the front's i am pretty much positive only come in that sizing. the rears should come in both NB + WB and if its the original wheel on the car it should be the WB sizing.
Yes, my build sheet is attached. They are slightly tucked. I think 15mm would be great at all corners. Is there a market for the OEM 5mm spacer? Maybe I can mitigate the upgrade cost?
File Type: pdf
Old 11-14-2017, 02:04 PM
  #38
myw
myw's Avatar
is your car lowered, any negative camber ? are the rear wheels the c4 ones (51mm offset)?
Old 11-14-2017, 02:11 PM
  #39
myw
myw's Avatar
15mm all around my friend is what i would recommend. basically what i am running on oem height.
Old 11-15-2017, 11:47 AM
  #40
Falcondrivr
Not lowered, max negative camber, stock C4S wheels (et51)
Old 11-15-2017, 01:36 PM
  #41
myw
myw's Avatar
i would assume it would stick out beyond the fender re oem camber, based on the other posts on the forums re spacer data on the oem 8 inch front wheel 8x19+57
Old 11-18-2017, 06:33 PM
  #42
LISsailor
LISsailor's Avatar
What is the best source for spacers? I assume they are easy enough to install. I have a torque wrench. What is the recommended Ft/lbs to tighten the wheels?
Old 11-18-2017, 06:44 PM
  #43
Hothonda
Hothonda's Avatar
Looks perfect!
Old 11-18-2017, 10:13 PM
  #44
Presto
Presto's Avatar
What size spacers are the ones who have the carrera sport wheels 11.5j with +67 offset (nb) and 305mm tires running? 10-12mm as per my measurements would be the max without tyre sticking past the fenders. 15mm if you have aggressive rear camber and a drop.
Old 11-21-2017, 02:04 AM
  #45
myw
myw's Avatar
10mm rear, and 7mm fronts (i am assuming your Carrear sports are 8.5 +55 (or +56). search for username destro (red c2s) with the same setup as you. he is running 5F/10R and when i saw his car in person we both agreed he has more room in the front, i.e. 7mm front is fine. he is running oem spasm suspension clearance.
Quick Reply: Spacers
