Spacers
Old 10-30-2017, 03:48 PM
FZP
FZP's Avatar
All this talk is cheap.....lets see some pics and descriptions so we make an educated call. Let's face it.....just another reason to see some lovely P cars 😎
Old 10-30-2017, 05:02 PM
myw
myw's Avatar
without the wheel design its impossible for us to help in an educated manner.
porsche makes multiple width and offset wheels for 997.
we have to see which design it is - but if its an unaltered 997.2 c4s (with no factory wheel upgrade/adjustment) then it will have the 8"+57F 11"+51R. and the info re the 12F/15Rmm spacers given will apply.
Originally Posted by LISsailor
Cannot recall the wheel design.
Old 10-30-2017, 11:56 PM
Para82
Para82's Avatar
Took this today, wide body
Old 10-31-2017, 03:18 PM
Falcondrivr
Falcondrivr's Avatar
You know it's not a wide body right?
I'm running 20mm spacers on all four corners on stock 4S wheels. I like the look and it does stabilize the car a little at the track. Got mine from FastCo USA in St. Pete, Fl (local) and they supplied the longer lug bolts that are needed. This video was looking at the paint. But it shows the offset with the spacers pretty well.
Old 10-31-2017, 10:59 PM
LISsailor
LISsailor's Avatar
This is how she sits as of now. What wheels are these again?
Old 11-01-2017, 07:49 AM
Wolfk
Wolfk's Avatar
^Carrera Classic
http://www.wheelenhancement.com/prod...arrera-classic
Old 11-01-2017, 03:53 PM
myw
myw's Avatar
were these on the build sheet as an option?
if they *should* be 19x8+57F 19x11+51R (standard 997.2 WB width and offset). the front's i am pretty much positive only come in that sizing. the rears should come in both NB + WB and if its the original wheel on the car it should be the WB sizing.
Old 11-03-2017, 02:40 PM
Wolfk
Wolfk's Avatar
15mm spacers front and rear on this C2
Old 11-03-2017, 05:42 PM
myw
myw's Avatar
beautiful! lowered?
glad to see another 15/15 owner.
Old 11-03-2017, 07:50 PM
Wolfk
Wolfk's Avatar
Yes, lowered on Bilstein coil-overs.
Old 11-04-2017, 09:38 AM
shekmark
shekmark's Avatar
Can I do 21's all around on stock C4S, or is 15mm the max? Mine came with factory 5mm. I wonder why they bother to offer it, as 5 mm does not do much.
Old 11-04-2017, 10:27 AM
FZP
FZP's Avatar
Wolf. Have you lowered yours also. The way the wheels sit is just lovely.
Old 11-04-2017, 03:55 PM
myw
myw's Avatar
15mm max front and rear - assuming you are running 8"/11" wheels.
you don't mean 21" (diameter) wheels do you?
Old 11-04-2017, 04:32 PM
shekmark
shekmark's Avatar
I meant 21mm spacer . Seems like I’m reading about guys with 15mm spacers saying they are not enough so I thought 21’s. I already have 5mm. I am going to do the straight edge test. I have not done that yet.
Old 11-05-2017, 12:30 PM
SToronto
SToronto's Avatar
Received 1,149 Likes on 752 Posts
Looks great! How are the Bilsteins? I’ve been waffling in putting those in for 2 years now.
Quick Reply: Spacers
