New guy with used 911 questions
Looking to buy my first used 911 (2006-2007) and have some questions, especially for CA guys.
- Would you consider buying a car that started life outside CA, knowing that you may have possible problems down the line passing smog tests?
- Would you buy a 2006-2007 without documentation regarding the IMS and or RMS fixes?
- Is 20,000 miles on a 2006 actually too low, the theory being it probably sat for extended periods of time, which may not be good?
- Has anyone purchased a 2006-2007 from a used car dealer and gotten the extended warranty that expressly covers the IMS / RMS issues?
Thanks. RJ
Thanks. RJ
Thanks. RJ
Thanks. RJ
- No problem with buying a car that started life outside CA, just check undercarriage for any rusty areas, Smog should be no problem, just make sure it has the original Air Intake or you can get a hold of an Original Air Intake if it has an aftermarket one.
-2006/2007 even some late production 2005s have the bigger IMS so that is not something you need to even worry about..the IMS cannot be changed it them & mechanics will tell you the double row bigger IMS there are no documented cases of it actually grendading. I have a 2005 and went to do IMS when it was time for the clutch & mechanic called me with good news saying it has the 2006+ IMS.
-20k miles is low, i usually prefer higher mileage cars, however that doesn't mean that anything is wrong with the car, get a PPI & you should be all good.
-Again with the IMS/RMS blown out of proportion thing, first of all 2006-2008 DO NOT HAVE THE IMS YOU NEED TO WORRY ABOUT , As for RMS, that is a simple Gasket, no big deal at all...I don't buy those aftermarket warranties, these cars are bulletproof if maintained well & pass a good ppi.
Hope those answers help you make a decision
Tarek +1. I bought a 2006 C2S 2 years ago in New York with 27k miles on it. It now has 50k miles. It had no service records. I had a P dealer do a PPI and they said the car was great. I shopped the warranties and worried a little but decided not to buy one. I have only needed normal maintenance things for 2 years.The car still makes me smile a lot. Do it.
The cars overall condition should trump where it came from. With that said, a South Western car will be easier to keep up because we dont have the road salt issues for the most part. I wouldn't worry about the IMS on an 06+.
In CA the seller is REQUIRED to have the car smogged. If it was an independent dealer selling, I would have a PPI done at a reputable shop and another smog. This prevents them from smogging with their 'guy'.
RE low miles, a good PPI will find issues if any.
Out of curiosity, does Porsche make any changes to the cars that are sold in California? At first blush, I would assume not. The primary Cali-smog issue I would look out for would be aftermarket parts or tunes on a car that might not be Cali-compliant.
Also, while he RMS is just a seal, it's a bitch to get to. It's fairly easy to see if it is leaking, but it isn't something you just pop out and pop a new one in, unless you consider removing the transmission a simple job. Whether or not the '06-'07 cars are prone to leaking, I don't know the answer to that. I do know (anecdotally) that RMS leaks are more common on cars that are not driven a lot.
Good luck in your search!
If you want to swing by Long Beach and we take a ride to Santa Monica together to look at the car you wanna check out let me know-
I feel like IMS is a non-issue these days as the late large bearing almost never goes bad and the early ones are upgradable. The only major thing I would be concerned with is bore scoring (how my engine went south) and it's not like IMS in that it doesn't blow up the engine from out of nowhere.
The greatest issue is those "minor" failings which happen on an 8-10 yr old car and can add up to a fortune.
Proper installation of the RMS seal requires a special installation depth tool to be done properly. If replacing that, also make sure you get the updated seal that has multiple sealing ribs.
Get a real PPI, not just someone to go look at it. You also need the DME printout to look at operating hours. overevs on the motor, and logged misfires if there are any, and which cylinder(s) they're in.
Also, even though the car only has 20,000 miles, if never done, it's going to need a water pump and serpentine belt since the pump bearing has been sitting in coolant for 11 years so factor that cost into your purchase price.
They're awesome cars - hope the purchase works out for you.
A major service would be: New spark plugs and maybe coil packs, new air filter, new cabin filter, brake fluid flush and fill, new serpentine belt, oil and filter, wipers, and perhaps new tires if it's rolling on the originals it came with. All that added up will be a bit pricey. Not to scare you off, but being honest.
I bought an '06 C4 coupe w/68k miles on it in December and I got a powertrain warranty on it. It does cover IMS issues. I spun a rod bearing in June, and thankfully, it covered most of a used engine to replace the blown up one.
As for these cars being bullet-proof, I have to disagree. This car has had more problems than all of my other Porsches put together (and that's a long list). Some normal use stuff: broken undertray, torn CV boot, that kind of thing.
But it also had a ton of other stuff, and that's even after passing a PPI and full history of service records. The engine blowing up was a big one, but there was also two failed door modules, a broken interior door handle, PCV, fuel tank vent vent cap and canister control valve, oil pressure sender, clutch return spring, alternator, water pump, battery, belt tensioner and rollers, oil galley freeze plugs.
It's gotten me to the point where I don't trust this car to get to to the grocery store, much less the 500+ mile trips I need to take over the holidays. From my experience, I would pass on any M97 911, and I wouldn't suggest passing up one of those warranties. The car isn't fast enough, fun enough, exclusive enough to justify what it costs to own. I've had a lot of Porsches and the 997 is easily, by far, the worst one. It's not only the worst Porsche I've ever owned - this is one of the worst *cars* I've ever owned.
I never had an IMS issue, though.
Go with caution.
Go with caution.
I bought an '06 C4 coupe in December and I got a powertrain warranty on it. It does cover IMS issues. I spun a rod bearing in June, and thankfully, it covered most of a used engine to replace the blown up one.
Go with caution.
Go with caution.
You must have received what we call in manufacturing a "Friday car" where everyone is ready to leave for the weekend.
