Oil Change service indicator reset ?
I use the icarsoft programmer. I made a video on how to change the oil with my 8 year old daughter. Later in the video I go through the process of how I use the programmer to reset the service vehicle message.
https://youtu.be/p38b5BLRHaQ
AmericanPupusa (05-08-2020)
+1 on the Creader
You might be onto something here...
I got a BlueDriver a couple years ago. It's a Blue Tooth sender that plugs into the OBD port and works with virtually any car or light truck with the port. You open the phone app, plug in the sender, there's your car info including vin. No endless menus. Nice high quality image. Great for quick checking codes and resets. When I got mine it was less than $100 from Amazon. It's not a Durametric, but you wouldn't expect it to be. Just make sure your phone is compatible.
