Amazon Echo in my 997.2
Hi all,
I am looking at putting an Amazon Echo dot in my car. 997.2
I am thinking of hooking up the echo in the AUX port and power it with the USB port (if it can power it).
I will hook up a mobile hotspot in the car too to keep it connected.
Has anyone done this setup?
If you setup a hotspot and give it power, sure, you can do it... but, I have to ask, why?
If you already have your phone there, what does Alexa offer that you can't get from Google Now or Siri? It seems like you're inventing a solution to a problem that doesn't exist.
The problem I am trying to solve is having to access my phone to select music while driving etc...
If it was integrated with PCM, then maybe.
What I wrote before my login expired was that I was used to hooking up my phone to my BT and controlling it through steering wheel controls in my previous car. But now, I don't have that option.
I also don't have a lot of media to put on an iPod.
So my choices are limited... That's where Alexa comes into play.
I also work at a company that sells data and hotspots so I have access to that stuff.
So you are saying that I should/could just hookup my phone to the aux port.
Your phone should support the same voice recognition features that Alexa does. I can say "OK Google, play rock music", the same way how at home I say "Alexa, play rock music." No?
Do you have an android device? Even better, use the Android Auto app. It will auto launch when it connects to your car's bluetooth and supports full voice commands for navigation/text messages/audio. Just mount your phone on the air vent so it's in eye sight.
I think you'll have to reinitiate the echo every time you get in the car. It won't have a power source when the car is off.
