Trickle Charger for 997.1
#46
I bought a Battery Tender Plus, the longest plug wire, and a new battery for my 1963 Chevy Impala in 2005. I only used the car occasionally and that car battery was still going strong in 2016 when I sold it. I put the plug on my 997.1’s battery when I got it late November ‘16 and Use it for winter storage. I ran the wire through the frunk and keep the hood latched but not closed. I used a screw driver driver to flip the hood latch so the frunk light goes off. The battery tender is wall mounted in a stainless steel basket to keep it out of the way. I move the car every 2 week (pushing it around) so the tires don’t flat spot, and the extra long plug allows me to do that without unplugging the car.
funkanimus (10-06-2019)
#47
I got a CTEK MUS 7002 plus the (non-indicator-type) cig plug from etrailer.com (no affiliation, they just had the best price I found), seems great. I got that model because it's top of CTEK's consumer line and has a "supply" mode whereby you can disconnect the battery for whatever and not have to do the window reset after.
#48
After doing some OCD triple checking on locations to mount indicator, there's a little 'well' at the driver's side windshield wiper that created a space large enough to be filled by the indicator plug. I mounted my indicator there, routed the wires under the plastic shield, then to the battery. (Had to cut and splice/solder the wires.) Used a black zip tie to pull it snug. So far, loving it. Hood closes fine, plug is under shade so visible as heck, not in my way, and plugging in couldn't be easier. Thanks so much for the idea!
Wire routing hole.
Drilled for zip tie, pulled snug, installed weather proof cap (comes with indicator).
Needing a charge!
Getting a charge. All's well.
#49
Received 2,094 Likes
Nice Work!
TerrestrialFlyte (08-05-2021)
#51
Load switch-off after 2 hours - If the ignition key is removed, loads which are switched on or are in standby mode (such as the luggage compartment light, interior light and radio) are automatically switched off after approx. 2 hours.
#52
Had the Porsche version on our Boxster. Had a Battery Tender brand one that had the BMW logo on it which I used on my 335 and my S4. On the 911, I bought the CTEK Multi US 3300 and have been happy with it. Also got the cigarette lighter adapter which works well and is currently how I am using it. My friend uses that one on his 997 turbo and another friend uses this one on his M5.
#53
To those of you using the cigarette lighter to maintain the battery, how much do you lower your window to run the cable.
The reason why I'm asking is due to the window seal motor when you shut the door.
Is it only activated when the window is fully up? I'm assuming cracking the window just enough to feed the wire through should be good enough, correct?
I have the Battery Tender Jr on my cars and bikes so I'm just waiting for the cigarette adapter to ship.
#54
I don't run the cord through the window, I drape it across the the lower door sill. So far no problems, does not leave a mark on the lower door trim. My car is outside, no garage, so I have to keep the window up.
#55
Across the door sill area or through the front/rear? By any chance, can you post up picture of your setup? I'm assuming you kink the cord to contour the bends of the kick panel. The cord is thin enough to not make an impression on the weather seal.
#56
#57
My cigarette adapter came in so I'll try this out. I'd rather keep my window closed in the garage too.
Your charger can charge all types of batteries. The motorcycle mode reduces it to 800mA.
#58
I've been doing it this way the last year and a half- No problems. There is no difference in feel when you shut the door. The Porsche charger is cigarette charge only, no adapter or options on my charger. So I put it into the cigarette lighter. I've never checked to see if I could use the plug in the passenger side foot well?
#59
#edit
Very awesome, thank you for the tip! I just test fitted mine and it closes fine.
#60
Basic Sponsor
Thanks for all of the ideas in this thread! I have a CTEK MUS 4.3 and i added the indicator pigtail. I routed it up to the cowel on the passenger side and made a little cut so i can tuck it away when not in use.
High Temp Caliper Rebuild Kits; Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
