Turn off TPMS warnings but still get pressures readouts?
Is that possible? I've seen posts that mention turning off TPMS but does that completely disable the system?
I guess that what I would like is to be able to just turn off warnings of pressure differences but still get the display of the tire pressures.
Showing the pressure differences and showing the tire pressures are two different menu selections. I believe the owner's manual will tell you how to select the display you want - about page 110 in my manual.
To completely disable the TPMS you have to disable it using PIWIS and also disconnect the module located inside the frunk.
I realize that since English is not my primary language something may have been misconstrued in the way I posed my question. Hence, I will make another attempt at seeking counsel for what I hope is attainable.
First of all, I do NOT want to totally disable and much less remove my TPMS system. What I really seek is to maintain the actual display of tire pressures BUT NOT HAVE THE SYSTEM WARM ME that I need to add air because my pressures are out of range.
In other words.... maintain the pressures display but do away with the warnings.
Thanks in advance for any insight or suggestions.
I have a 997.2 base carrera optioned with 19in wheels and limited slip. Without that option base carreras come with 18 in wheels. When I go in and set up tpms on the dash I can select between 18in winter, 18 in summer, and 19 in summer tires. If I select either 18 in winter or 18 in summer option it allows me to run lower pressures (low 30s) before light comes on even though I'm running 19in summer tires.
It might be possible. In Durametric Pro there are options to disable individual warning messages. Not sure which ones map to the TPMS warnings you want to disable though. Start with floatingkiwi's spreadsheet and look for RDK messages (German abbreviation for TPMS)
https://rennlist.com/forums/997-foru...ns-manual.html
He said he doesn't want to disable - I believe what he wants is the display to show tire pressures all the time and not switch over to a different display when the pressures drop below a computer set threshold. Sorry I can't find the solution for that.
I get warnings while on track running 'flat' pressures and it's a nuisance having to clear the OBC white flat out on a tight right hander.
Would love to fix that.
Not saying it's not possible, just not very easy if it can be done.
Note that some changes in the instrument cluster module require reset of the module for them to take effect. You can do that with the Durametic too. Hope someone has better luck than I did. This is a really nice feature if someone can get it to work.
Thanks for your help Mike.
To the OP: Why are you getting warnings? Set your TPMS system for 19" wheels and set your pressures correct (cold) 33/37 PSI and you should get no warnings.
In any case... which specific warning do you see?
His post was pretty clear that he wants to do away with the warning that occurs when he has his actual tire pressures outside the recommended ranges.
I just pulled my 997.2 from storage where I had extra pressure in the tires. Released air to set them to 33/37 cold and after a few miles, the TPMS system triggered that there's a flat. I've driven about 70 mi hoping it would reset. No dice so far. Wish there was an easy way to tell the system that 33/37 cold is good
