Help with OVER REV REPORT
I am interested in a 2006 911s PPI shows the below over rev report
Should I be concerned?
OVER REV REPORT-
RANGE#1X962; RANGE#2X119; RANGE#3X17; RANGE#4,5,6X0
997 Carrera
Range 1 > 7300 and < 7500
Range 2 > 7500 and < 7700
Range 3 > 7700 and < 7900
Range 4 > 7900 and < 8400
Range 5 > 8400 and < 9500
Range 6> 9500
OVER REV REPORT-
997 Carrera
Range 6> 9500
I beg to differ. It's not perfect with range 6 ignitions.
Just as important is the hours in which these ignitions occurred. Did they just happen? Damage may yet rear its ugly head. where they 200 hours ago? Less dire consicuences.
Former Vendor
I think you are reading this wrong ( at least I am reading his post different )
OVER REV REPORT-RANGE#1X962; RANGE#2X119; RANGE#3X17; RANGE#4,5,6X0
this is just what reach range means
997 Carrera
Range 6> 9500
I think that he is good to go
4 to 6 have ZERO
The numbers alone don't mean much without the hour stamp as to when they occurred and how many hours are currently on the motor.
If whoever pulled the DME data and sent it to you like this (without the hours) may I now the hour info might cause concern and intentionally omitted it. You need the full report.
While normally it would be very important to know the number of hours since the overrevs, I wouldn't worry one bit in this case with zero in ranges 4-6 and just 17 on Range 3.
