Removing leather wrapped inner door sill - How?
Old 07-25-2017, 07:46 PM
Rampage
Rampage's Avatar
Default Removing leather wrapped inner door sill - How?
Hey guys, I'm looking for instructions or tips on how to remove my leather covered inner door sills on my recently acquired 997. It has Natural Brown leather sills from the factory, but the previous owners were not that careful entering or exiting the car and the drivers side is in rough shape as you can see (although the flash makes it look worse than it is).
I'd like to bring the sill to a leather repair shop and see if they can repair it or at the least make it look better than it is currently. I found the DIY for removing the standard plastic pieces, but my leather parts don't seem to have access to the plastic plug or the hex head cap screw.
https://rennlist.com/forums/997-foru...uff-plate.html
Anyone have experience with this ??
My sills pictured below. As you can see I don't have access to #1 or #2 in the parts diagram above ... Running my fingers along the surface I can feel the sink mark where the hole would be in the base plastic part.
Old 07-26-2017, 12:54 AM
ervin881
ervin881's Avatar
My guess is the screws were simply never installed. Try prying them "up". There are four or five clips that engage with the metal sill. It's easiest if you pry with something that won't marr the pieces. It takes a bit of force to disengage them.
Old 07-26-2017, 08:27 AM
Rampage
Rampage's Avatar
Thanks, I was thinking the same but just nervous to actually do it. I'll give it a shot tonight.
Old 07-26-2017, 01:39 PM
OKB
OKB's Avatar
I doubt if it has screws, just pull it up.
Old 07-26-2017, 03:25 PM
Petza914
Petza914's Avatar
Received 6,601 Likes on 4,197 Posts
There are 2 screws accessed from the seat side with plastic caps covering the holes. You'll need a low profile 90 degree bit ratchet or just a screwdriver bit with a 1/4" wrench. The two screws clamp against a flat plastic area molded into the sill piece itself to hold it down tight, once installed. Once the 2 screws have been loosened (not removed) you'll be about to use a trim tool to pry it up and remove it. Not loosening the screws first could damage the tabs on the sill on the underside where they clamp.
They're actually shown in the parts diagram you posted.
Old 07-26-2017, 06:13 PM
Rampage
Rampage's Avatar
That is true for the standard plastic piece, but my piece is leather covered.
In the photos I posted of my actual part you can see there are no holes, and no flat plastic cover - and the reason for my hesitation.
Old 07-26-2017, 07:04 PM
Petza914
Petza914's Avatar
Missed those pics the first time around - guess you don't have the screws...
Old 07-26-2017, 08:03 PM
Rampage
Rampage's Avatar
Conclusion: Just pull up!
Cap screws are still there, just not tight. Here's a pic of the backside. You can see that the hole is there in the base plastic piece.
Now to see if I can get it repaired ...
Old 07-26-2017, 08:44 PM
apperception
apperception's Avatar
Default I was sad because my leather was scuffed...
...until I met someone whose inner sill was not even covered in leather
sorry, I'm just a bit jealous.
Larry in Georgia
Old 07-26-2017, 09:44 PM
ervin881
ervin881's Avatar
Try Classic9 Leather in Michigan. If you can't find local, Classic 9 has done many of these.
Also Exclusive Option.
Old 07-28-2017, 12:58 PM
EXCLUSIVE OPTION
Basic Sponsor
EXCLUSIVE OPTION's Avatar
Default Inner Door Sill Replacement
Hello Rampage,
While some shops will be able to fix your problem, there is much damage to the leather itself. Our inner door sills have factory matching leather and stitching to compliment the rest of your vehicle so you can rest assure it will be a match with no issues.
Fine Leather Parts For Porsche
Email:info@exclusiveoption.com
Shop Online: Exclusive Option
Old 07-28-2017, 01:06 PM
Petza914
Petza914's Avatar
Not sure if you have any other materials in your car, but a harder, more durable material on the inner sill will look better longer. I have a lot of CF in my car and both my inner and outer sills are CF. I keep them waxed and there's not a scratch on them, even though I'm sure I've accidentally run a shoe across them a time or two. If you don't have anything else that's a good complement, then leather looks really nice, you and anyone you drive in your car just have to be really careful with it.
Old 07-28-2017, 08:27 PM
OKB
OKB's Avatar
you can put clear bra on those and you may never get a scratch. When i go on trips I put it all around the opening , take it off when im home. its good for rain and mud and i put it on the carpet too.
Old 07-29-2017, 10:54 AM
Rampage
Rampage's Avatar
Thanks guys!
I'm going to look into my options for keeping it leather, either repair or replace. I do have a few painted surfaces (setbacks and centre console), but I want to try and keep the leather theme going since the car also has the steering wheel and fuse box cover in leather already.
Old 07-29-2017, 02:19 PM
OKB
OKB's Avatar
you can repair leather with a filler, then repaint. It looks ok but you can always see it. The part is so low and out of sight you may not notice it unless you see it in the bright light
Quick Reply: Removing leather wrapped inner door sill - How?
