991.2 steering wheel on 997.2???
Has anyone done this swap? I know I will have to purchase a new 991.2 airbag and a new 991.2 steering wheel. I really want a 991.2 steering wheel with multifunction controls. If this doesn't work I'm just going to do a 997.2 multifunction wheel.
Thoughts? Comments?
Thoughts? Comments?
See this thread:
https://rennlist.com/forums/997-foru...-retrofit.html
You probably need the 997.2 control module.
OP you should already have the 997.2 module so you would just a little bit of PIWIS coding and thats about it + the module from the guy on the FB group - many ppl here have bought and and are running the 991.2 wheel with MF on the 991.1/997.2/997.1 with all buttons fully functional
vokain (04-12-2022)
Thanks for all of the input guys. Suncoast is the way to go if you want a stock 991.2 MF Steering wheel.
Sport wheel in leather multi-function $995
991.2 Airbag (Leather) $1450
GPS Adapter from Yuan Li $299
So, all in and done, approximately $2744 + about 2 hours of diy time. Of course, I will still have to pay to have it programmed since I didn't have multi-function to begin with. I'm pretty sure that Stahl Motorsports in WPB has a PIWIS and I would much rather have them give it a try than Braman Porsche. I may also try Champion Porsche in Coconut Creek, they seem to be much more in tune with mods than Braman.
Thanks for all of the input guys. Suncoast is the way to go if you want a stock 991.2 MF Steering wheel. Sport wheel in leather multi-function $995 991.2 Airbag (Leather) $1450 GPS Adapter from Yuan Li $299 So, all in and done, approximately $2744 + about 2 hours of diy time. Of course, I will still have to pay to have it programmed since I didn't have multi-function to begin with. I'm pretty sure that Stahl Motorsports in WPB has a PIWIS and I would much rather have them give it a try than Braman Porsche. I may also try Champion Porsche in Coconut Creek, they seem to be much more in tune with mods than Braman.
997.1C2S (01-16-2022)
don't forget when selling your current airbag + wheel that will also reduce your total cost of the upgrade as well.
if you are buying absolutely brand new wheel + parts then yes it would get very very expensive.
My question - will the heating function on a 991.2 with that capability work on my car with your STMV1-H adaptor? (I also would look to activate the multi-function controls - which I understand would be enabled in software setup.)
Thank you!
I have a 997.2 with the original heated steering wheel - no multi-function. It is a PDK car.
Thank you!
Thank you!
MF can enable by PIWIS like this
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/960x354/de332f66_6b75_4b53_8751_42a851912f98_056010e0eac67295a9f304598e0529d38084305d.jpeg)
The following 2 users liked this post by Yuan Li:
Ironman88 (04-25-2020),
JVinPortland (04-25-2020)
