997 exhaust leak causing idle faults
Hello, I have just purchased a 08 997 gen 1, I have had the fault code p02190 I have looked and found a small leak from one side of the exhaust could this be the culprit?? regards mark
People have had luck cleaning their MAF. Clean it with MAF cleaner only. Let it dry before reconnecting and powering up the vehicle. You will need a security torx to get into it.
