Voltage at 12.6v when running. Alternator? Or something else to check first?
I'm guessing the alternator is shot, but anything else to check before I bite the bullet?
Any diy for a replacement?
Thanks!
Thanks!
Your car should quickly throw a bunch of lights (ABS,PSM, battery etc) if your alternator is bad and when I say quickly I mean less than 5 mins of driving. If you want to replace it for piece of mind it is pretty easy just remove the y pipe and your drive belt and then unbolt the alternator.
Are you new to the car? Or did the same car previously read higher?
Mine would fluctuate between 11.2V and 12.5V, then sometimes normal 13.5V +. I had no codes or warning lights. I replace the alternator with a new Bosch. All is good now.
You probably have a bad voltage regulator which is inside the alternator.
Is this with the AC on and other accessories?
Why not just leave it alone? It's not broken.
I say it's not broken cause it's not right? Does the car still drive around? If yes, then why worry?
Also are you reading the dash gauge? Put a real gauge on it and read it.
This thread has a lot of good info if you have time to read through it all.
https://rennlist.com/forums/996-turb...xperience.html
I replaced my generator as PM.
