Fuel pump failure
just cost me $1000.00 to replace one at the dealership since the car died 5 mins way from one. was no point in towing it home and then ordering the part. should be good for awhile now ha
Most of the time it is the U shape hose on the pump that is punctured and can be replaced...Cheap fix!!!!
https://www.6speedonline.com/forums/...fuel-pump.html
same
Just lost a pump in my 996tt at 45k miles. Hadn't noticed but he said that there are two tanks, because of the AWD. Does it have 2 pumps as well or more? My BMW has 2 pumps but only one tank obviously, but there is a low and a high pressure fuel pump. The high pressure one is about $800.
It's an easy swap, google the diy here and you'll see how there are dual pickups for the hump shaped tank. At 15+ years old I would consider a new pump preventative maintenance you'll be glad you did. Stuff rarely craps out in a convenient fashion.
^ +1
Interesting that Porsche still used the AWD hump tank on the US spec 997GT2/3. Only the ROW 90L tanks are flat bottom. The 996GT2/3 tanks are all flat bottom.
I had my mechanic replace with a Gates submersible fuel line hose see pic below. This after the OEM line ruptured (under warranty) and the new pump also ruptured...no problems since.
I would be worried about that pinching if it wasn't preformed in a bend. Does the length of that bend effect anything? Could it be longer? I was thinking of using this. https://www.horsepowerfreaks.com/-p-...FciEfgod_zIEXQ
Whole new pump is $482.97 with free shipping at warehouse33 (using the RENNLIST promo code). Not sure I'd want to spend the time and effort to rig something up on a part that vital given the price of a new one.
