911 tuning (Markski tuning) turbo intake system FS
My shop says labor to try to make this fit on a tip. trans. car would well exceed the cost of a mafless system/y-pipe with no fitment issues.
So I decided to sell it. $800.00 plus shipping.
Flex pipe turbo intake kit for NON motor drop install. Only for manual trans.
https://markskituning.com/product/di...ndable-tubing/
Thxs
Rich
Thxs
Rich
Both hard & flex pipe turbo intake kits will not fit on the drivers side with tiptronic trans. Only manual trans.
2.75 diameter flex piping included with Markski's kit will get crushed at the trans area drivers side.
Has anyone figured out how to get around the tip. trans. obstruction with flex piping etc.. 3 inch hard piping just wont fit-ever.
I know someone has done it with a tip. trans.
Thxs in Advance.
Rich
Thxs in Advance.
Rich
Can you see if two parallel flexible tubes 1.25" diameter each will clear the obstruction on the driver side? If so then it's just a matter of making a collector at each end using CF or fiberglass.
