M030 suspension
M030 suspension
Does anyone have the euro M030 suspension on there turbo. Do you have both the springs and shocks, or just the springs. The dealer said it is not necessary to change both. They will change the springs only, for $1350 and aligh. Is this a good way to go? Will it upset the cars balance? Is the handleing improved?
Do a search, there have been a lot of info on this subject.
To answer your question, your dealer is an idiot. The ROW suspension for the Turbo includes dampers (shocks) and springs. I would not just install springs only, they are designed to work with the Euro dampers, not the US ones.
Here's info:
http://www.carnewal-europe.com/cpx_p96008.htm
You can also go to www.carnewal.com to buy the parts a lot cheaper than your dealer. They also sell more agressive suspension setups for the Turbo.
The car is a bit lower, stiffer, and does improve the handleing imo...
Roy
Here's info:
Roy
TRB0 GUY
just curious.... Porsche used the same designation for the 951 S suspension package. Any possible relation?? Is M030 just a generic term for Porsche to show the suspension was upgraded from standard?
thanks,
Kevin
thanks,
Kevin
Turbo Ron,
glad u ask. my dealer told me the same thing when i wanted to lower my TT. they thought the shocks are the same & just need Euro springs. check what i got here:
http://www.6speedonline.com/forums/s...ight=euro+M030
as u can see, the shocks are actually different.
also check here & u can find the pics of my car after Euro M030 installed.
i got the whole kit from Gert at Carnewal.com. great experience!!! as always from Gert
PM me for pricing on installation. i might be able to help u out!
Is the car noticeably a much stiffer ride? Do you scrape a lot more on driveway approaches? I had the euro M030 on my C2. I loved it. That car started out a lot softer though. This turbo is firm to start out with. I am a little concerned it will be notibly stiffer than the C2. Opinions please.
I installed the ROW M30 suspension (purchased from Carnewal) on my 02 tt. Wasn't quite low enough for my taste but the ride was not harsh at all. I went with pss9s. I still have the M30. If your intrested drop me an e-mail.
I have the ROW springs and shocks on my '02 Turbo and am not real happy with it. I like the ride height , and don't have too much trouble with scraping the nose. On a smooth road or track the ride and handling are great. However, I find the ride on real-world Chicago area roads a little too harsh for my taste. It is hard to describe - there seems to be not enough compliance - the suspension transmits every little bit of harshness and bumps through to the driver. It becomes a busy ride , like there is too much information transmitted to the driver. I've experimented with tire pressures, to no improvement. I suspect that the shocks themselves have too high a degree of initial damping. I've thought about changing back to stock, but like the ride height and track characteristics of the ROW setup.
Anyone used a different shock with the ROW springs?
Originally posted by Turbo Ron
Some of you say the euro M030 is harsh and some say it is not?????????? Can anyone else comment.
If it were my car, I'd get a quality coil over setup -- both handling and ride quality will improve as compared to both the stock or Euro suspensions. If you want maximum flexibility to adjust both ride height and ride quality (shock rebound/dampening adjustments), try the Bilstein PSS9's. While the initial cost of parts will be slightly higher as compared to the ROW M030 (installation costs are the same), you'll definitely be happy with the results. You'll be able to fine tune the suspension for your specific driving needs/pleasures over time. Just my 2 cents.
I would guess alot depends on the roads in the geographical area the car is operated on. In the Chicago area we have relatively rough roads , caused by the weather extremes in the area - frost heaves, salt. heavy traffic, etc. I was amazed how smooth the highways were during a recent trip to Phoenix . I'm sure the ride my car with ROW would be far better in Phx than Chicago.
With the pss9, if your not happy with the setting, and need to readjust the setting, do you need to realign again?
