996 tt torq specs please
Can anyone please tell me where I can find torque specifications to:
Engine oil crank case drain plug?
Engine oil sump drain plug?
Turbo drain plugs?
Engine oil fill plug?
Engine oil filter housing?
Transmission gear oil drain plug?
Transmission gear oil fill plug?
Transaxle gear oil drain plug?
Transaxle gear oil fill plug?
Thank you!!!
Turbo drain plugs?
Thank you!!!
Darin plug on crankcase = 70 Nm
Drain plug on oil tank = 60 Nm
Drain plugs on turbos = 30 Nm
Oil filter cover = 25 Nm
Be sure to use all new sealing washers on the drain plugs, and replace both rubber gaskets on the oil filter support. I just did my first 996TT oil / filter change a few weeks ago; plan on the oil in the tank coming out fast, really fast.
