996 Turbo Forum 1999-2005
Brakes
Old 08-17-2016 | 12:35 PM
Edlebby's Avatar
Edlebby
Default Brakes
2004 996TT - stock brakes
how are they supposed to feel?
i have nothing to compare them to as i have never owned or driven another pcar
but to me, they are soft in the sense that they need a good amount of pedal to engage, engagment is linear, but grippiness doesn't really happen until lots of depression - until then, just kind of weak, mushy braking
fluid was flushed just prior to purchase (so several weeks ago)
pads "look" pretty new with a lot of material
rotors have a very slight groove at the top edge (27K mi on the car)
is this just par for the course?
thanks!
Old 08-17-2016 | 12:52 PM
napoleon1981's Avatar
napoleon1981
I recently bought a 2003 996TT and was wondering the same as you. Mine are also functioning fine, but it needs a good amount of pedal pressure to really start braking harder. In some ways they just feel like the brakes on my Honda Civic.
My buddy has a 964 with upgraded 993 turbo brakes, and it "bites" a lot harder.
Leon
Old 08-17-2016 | 01:15 PM
Jason @ Paragon Products's Avatar
I'd consider a pad change. Those are likely the original pads on the car and they're 12 years old. Lots of choices:
http://www.paragon-products.com/Brak...351.949.12.htm
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Old 08-17-2016 | 02:15 PM
Carlo_Carrera's Avatar
Carlo_Carrera
Yes, sounds like crappy brake pads.
Old 08-17-2016 | 02:19 PM
Third-Reef's Avatar
Third-Reef
Re-bedding them will sometimes give them a "fresh" feel for a while. I make sure and get on my brakes hard once every week or so, keeps them quieter and with better feel.
Old 08-17-2016 | 02:36 PM
Olemiss540's Avatar
Olemiss540
Mine are the same, very progressive and linear feel that you would expect from the fixed Brembo calipers, and the pedal effort is a welcome attribute as it allows you to better modulate the brakes depending on necessity. Does take some getting used to though....
Old 08-17-2016 | 02:38 PM
Edlebby's Avatar
Edlebby
Third-Reef - "re-bedding" just means braking hard? - to get a fresh surface?
Old 08-17-2016 | 02:39 PM
Edlebby's Avatar
Edlebby
replacement pads probably couldn't hurt...thanks for the responses
Old 08-17-2016 | 02:44 PM
Olemiss540's Avatar
Olemiss540
Personally, I would not mess with re-bedding unless you install new pads. With stock pad types, there is no reason the bedding process should need to be completed numerous times, and you risk unnecessary rotor cracking and pad deposits.
Old 08-17-2016 | 02:57 PM
911mhawk's Avatar
911mhawk
Do a couple of 130>60 like you just saw a cop and then run for a few to cool and see if the feel improves.
New pads if they are old, like everyone's said...
The pedal in these cars does take more pressure than many other cars, depends what you're used to/coming from.
Old 08-17-2016 | 03:09 PM
Olemiss540's Avatar
Olemiss540
Maybe not worth a trip to jail to bed-in your brakes. Below is a link to a standard procedure that I have followed with success.
https://www.zeckhausen.com/catalog/i...Path=6446_6443
Old 08-17-2016 | 03:10 PM
Edlebby's Avatar
Edlebby
ordered new pads...thx all
Old 08-17-2016 | 03:13 PM
Edlebby's Avatar
Edlebby
Dave - read your article - will follow to bed the new pads in
thanks to all
Old 08-17-2016 | 03:37 PM
napoleon1981
Please let me/us know what it did for you. I may do the same if have good results!
Old 08-17-2016 | 03:53 PM
Edlebby's Avatar
Edlebby
will do
